Octane on 17' GT
Wanka
Alberta
2017 Gt Convertible
I have been reading posts on this forum and somewhat confused on what octane is needed for the 5.0. In my manual it says 87 octane and it seems a lot of people are using higher octane without a tune.
I always understood that using higher octane than what the engine was designed for was a waste of money with no advantage.
I would appreciate it if somebody could clear this up for me. Here in Canada to go to 91 octane is almost 20 cents per litre more than 87, which can add up. However if there is a performance advantage it may be worth it.
Thanks...
UAmach1
Bullitt Hopefull
PA
Ford/INFINITI
The way modern ECU's work(after 2005 or so) is that they can use 87oct just fine. Benefit is it saves the driver money. When it detects a higher octane it will advance timing and produce more power. Benefit is more performance.
jacknifetoaswan
Charleston, SC
I'm fairly certain that my 2016 GT calls for 93 octane, but almost all modern engines, especially those with high compression, have knock sensors. If you put gas in with a lower octane, the knock sensor will identify it, then pull timing to resist detonation. You'll end up with less power than the advertised 435, but your engine will be safe.
JR
ghostnote
PR
Mustang GT 2015
On a stock tune, I see very little difference between 87 and 93. On a blind test, I'm sure I wouldn't be able to tell the difference.
By the way, the owner's manual specifically says there's a 1% power difference between those two fuels. on 435, that's less than 5hp. And when you factor in the 15-20% difference in price, well, premium really makes little sense. In my case, driving my GT about 6k miles per year, the difference is about $150.
On a tuned car, I'd imagine the difference is obvious.
jasonstang
Omaha, NE
2017 GB GT/CS 6MT
There is a dyno chart showed that even peak power is only 1% difference on stock tune, the mid range difference is about 20-30hp because how the stock tune is utilizing the extra octane around mid rpm range not at the peak.
Of course there is a difference between 87 and 91. Unless you are running a fixed timing and cam engine that is tuned for 87 only, there will always be some increase in performance and efficiency using higher octane. Whether it's worth the extra money or not is mainly personal choice.
sonicc
Mr. Bond
St. Louis
2015 Mustang GT
If I'm driving my car to work 5 days a week, I just fill up with 87. If I'm going for a cruise/track event/etc. I use 93.
beefcake
Bethel
2018 Ford Mustang
87 is fine, but like they said, 93 will maximize the power.
if you da tuner, at least 91 is what i would run
texasboy21
Houston
2017 GT PP. 2005.5 Audi A4, 1983 Silverado
My car feels like a dog below 5K RPMs on 87, and the gas mileage suffered as well.
It equates to a few dollars a fill up difference, so why NOT use 93?
AlmostFamous
This. There's a noticeable difference in mid-range power between 87 and 93 octane. There's another chart comparing 91 and 93 octane, and there was no power difference throughout the powerband. If you want maximum power on the stock tube, you'll need 91 octane or higher.
GTRacerX.
The Masked Racer
(25.688865, -80.393704)
Rex
2017 Ford Mustang GT Premium PP
Fast & Furious
i don't live my life 1/4 mile at a time :D
I do :D Whenever I find a nice long road with no traffic or side streets -
Am giving my Stang some exercise. ;)
FYI: I use 93 in my Mustang since day one.
