4leghorse
got mine back from the dealer today they did some update to the the trans and every shift is like butter now the 4-5 in track and sport that would throw me in the trunk is gone. Car drives great now extremely happy. Think they released a better tune for the 10r80Hi friends! I've been driving my GT 10 speed for over half a year now. It's been great. However, just want to confirm a few behaviors (quirks) of the automatic transmission, make sure it's not just my car that does these weird things.
Normal mode:
Everything is normal, although the car is pretty eager to shift to higher gears even at low speed. I've seen it shifting into 10th gear when going like 45 mph. Smooth shifts.
S, S+, Track mode:
2-3 shift very rough, almost feels like I got rear ended. 4-5 shift also pretty rough, but not as bad as 2-3. However, the rough shifts are not as noticeable if I'm press hard on the accelerator. If I floor the gas while shifting from 2 to 3, it's not rough at all. The shift is only rough when I do it while not giving it a lot of gas.
S, S+, Track mode (paddle shift):
Taking off in 1st gear, after pulling the upshift paddle, it takes forever (1-3 seconds) for the transmission to shift into 2nd. Even moderately pressing the gas paddle, the transmission won't shift from 1 to 2 until I'm almost at 5000 rpm. Pretty annoying.
Down shifting from 3 to 2 sometimes takes a while (1 second ish).
If I want to drop 4 gears at a time, I quickly pull the downshift paddle 4 times, but the transmission sometimes would issue two separate shift commands, like it would drop 2 gears and another 2 gears.
Drag mode:
Chirps the tires on every shift.
All modes:
Very occasionally I would take off from a stop in D, giving the car gas and the car would just sit there and rev, almost like it's in neutral for like a second. Then it engages drive and starts to go forward. Everything would be normal after that. This has only happened to me twice since I owned the car.
When the car is still cold, the idle rpm is kind of high. If I shift into D and just creep around parking lot, sometimes the car would increase throttle and speed up on its own for 1 to 2 seconds, then slow down. Not sure what's going on, almost like the transmission is shifting into another gear and shifting back.
It takes a couple of seconds to engage D from R. I scared myself the first time when I was backing up on a hill, trying to park in tight space. When I went from R to D and let go of the brake, the car started to slide backwards for a bit.
Do you guys agree with the behaviors I just described?
Final question: do you guys like to drive in paddle shift mode? Aside from the 1-2 slow shift from the start, the paddle mode has been quite fun. The shifts are mostly quick and responsive. When I first drove the car around mountains, I put it in auto mode, and the car would get pretty confused with what gear it wants to be in (the downshifts when I brake at corners make pretty sweet sounds tho). With so many gears, I feel like it's constantly shifting. I only use auto mode when I'm feeling lazy or around parking lots (the rough shifts scare me in parking lots!). Otherwise I use the paddles. What are your thoughts?
