No start after injector swap
Roushblown5.0
Northville michigan
2014 gt
Hello,
Had a procharger on my car and removed it last week. Was running ID1050 injectors. Removed the kit and turned the car on and it ran fine.
I then pulled out the ID1050s and put stock injectors back in and now the car won’t start. Cranks but won’t fire up. Waiting for a new tune to come in for stock injectors buy im Assuming the car should at least start with the current tune, correct? Or do I need a tune for stock injectors at least to turn it on? Would like to move the car while I wait for the tune to come in. Thx.
daSNAK3
Cary, IL
Jake
2021 GT
Your tune is probably way off now, with removing the blower and changing injectors.. I'd def wait for the new tune.
LOL WUT
Illinois
19 GT
Agreed, the car is expecting far different from what it has in it right now.
HKusp
Hampton, Md.
Jason
Don't run it until it's tuned. That being said, did you bleed the fuel system by pulling the fuse for the fuel pump and running it until it died? If so, did you re-install the fuse for the fuel pump?
MKL_DS
Central Forida
2020 GT PP1
The stock PI injectors are tiny. Going from them to 1050s is a huge change in flow rate and requires a bunch of changes to the calibration to make them work right.
illadvised
San Diego
Brian Spilner
2015 GT - 6R80 - Paxton 2200SL
Did you try the stock original tune? You are on a stock car with no blower currently?
Roushblown5.0
Roushblown5.0
Northville michigan
2014 gt
Thanks everyone, new tune came in and car fired right up...car wouldn't even start with the stock injectors and tune for larger injectors.
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
Puddintane
'17 S550
that's because the 1050 inject a shitton of fuel, so it's tuned way down for idle/startup (way way way less fuel). No when you put that stock injectors in, you can imagine the fuel delivered through the injector would be next to nothing. Hence it not starting.
