No Lift Shifting?
SLOBullitt
Paso Robles, CA
2019 Bullitt
My experience. I tried a NLS..... once. 6Kish rpm. Sheared off a few driveline bolts. It was covered under warranty, but I won't be trying it again.
BurnCycle
I drank what?
Chesapeake
2016 GT
Tried it once on the 1-2 shift and swore I wouldn't do it again. Thought I was going to end up in a You Tube video. Now the 2-3 shift was a 'wooooh' moment with a evil grin associated with it.
BULLITT480
2019 BULLITT
This is an old 60's trick. It keeps the revs high and stays in the power band. But be very very careful. This is an art which requires a lot of practice. If you do not have perfect timing you can float the valves, break valve springs, etc if there is not a fuel shutoff, you can potentially damage the transmission, the synchros, and the engine. It is fantastic and fast when done right. But if you are off the least bit you can cause severe damage. Good luck
NGOT8R
Adrian
2019 Bullitt
I know this is standard on the Mach1, but I wonder if this feature can be activated via the tune in the GTs and Bullitt? Anyone know any Ford engineers with knowledge of these cars that can confirm whether or not this is doable?
luc
CA
2017 GT with PP
All power packs have nls
So it can be done
Bulutt
Australia
2019 Bullitt
If you want to shift fast get a dual clutch transmission. Cant be beat for speed and ease of shifting.
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
Ronnie Sox?
luc
CA
2017 GT with PP
Wanna back that up? I've not found ANY one with the 2018+ Power Pack also get NLS to work. Only 15-17.
You could be right since I have a 17
Sad that Ford would downgrade the PP for 18 and up
K4fxd
NKY
YES!!!! Of Sox and Martin fame
Yea, Ronnie was the only guy ever tested to shift faster than an auto.
I was a Mopor guy back in the day, Been to Landy's shop.
I love my coyote mustang but I loved my 426 hemi roadrunner also.
Dfeeds
Illinois, US
So it can be done
2018+ MY has the gen 3 coyote so the power packs for the gen 2 won't work. Ford only released one power pack for the gen 3 and it only works on the GT. It doesn't work on the bullitt because the bullitt has the gt350 IM and the tune is for the GT IM. So none of this is relevant to the OP.
If you mean to say it can be turned on with a third party tune then I'll concede to not knowing. But as far as I'm aware, even the power pack doesn't have NLS.
