Rattle shifting through gears
mAkI
Los Angeles, Ca
Moiz
2019 Bullitt
I haven't owned a stick shift in 9 years. I was curious about a slight rattle/grinding noise I hear some times when shifting up fro 1st to 2nd and 2nd to 3rd sometimes. Car is driving fine though. Is this something I should be concerned about or is it normal? My last stick shift car was a 4 cyl eclipse gsx and far as I can recall, there was no such noise shifting between gears. I am changing oil to inspect for any metal shavings this weekends just to be on the safe side. I'm at 5100 miles.
BrettT
Richmond, BC
Brett
2019 Bullitt, 2006 Jetta 2.0T, 2013 Escape SEL
It can be a bit "clunky" at times (once in a while), but I cannot say I have noticed rattle/grinding noise. I have just shy of 3,100 miles on mine. Overall it's pretty smooth...
OldPhart
Rochester, NY area
Bruce
‘05 GMC P/U, ‘17 Impala, 19 Bullitt
Hi Brett - It’s likely normal and of no concern. Your description somewhat matches what I hear and experience. Shifts generally get smoother as you shift through to the higher gears which is the norm. You’re probably too young to have experienced a Muncie “Rock Crusher” 4-speed. They sounded like crap but were next to indestructible. This transmission is like a knife cutting through soft butter in comparison, but it will still have some feel and noise. If your not hearing clunks or loud bearing type noises, relax and ignore it - turn up the volume on that nice B&O stereo... Bruce
harmonica2
Los Angeles, CA
Ethan
2019 Mustang Bullitt
I get that sound when I have the clutch halfway down longer than I should. Releasing a bit quicker should keep that from happening. In general, I find shifting the Bullitt a much different experience than my last manual, a 99 Miata. At 600 miles I'm still learning, especially at revs beyond 5000, which is an entirely new experience for me, and I'm trying to avoid a lurch from 1-2 at high speed.
