New whipple 3.0
matt1234!
2020 Mustang GT
So I just had the whipple 3.0 put on the 2020gt. Not familiar with it just yet but it doesn’t make boost until at least 4K rpm. Is this how it’s normally run or is there a tune to have it boost sooner? Thanks guys.
robvas
MI
2011 GT
Tune doesn't control the boost. It should make boost when you floor it at any RPM.
matt1234!
2020 Mustang GT
So throttle controls boost? I could expect boost at 2k if I completely open it up then?
robvas
MI
2011 GT
If you don't have the throttle open far enough, the bypass will be open and you won't make any boost.
Whitedevil95
Temecula, CA
J.P.
2022 Mach 1 HP
You only make boost at Wide Open Throttle. Not sure if this is what you are asking. Also you shouldnt be at wide open throttle at 2k rpm which can cause major detonation, but technically yes if you floored it at 2k rpm you should show full boost.
Wolfys11
New york
Jakub
2023 Mustang Gt
This only applies to high load scenarios such as towing or more realistically a high gear. 2nd or 1st gear wot at 2k rpm is fine, itl blow the tire though
Whitedevil95
Temecula, CA
J.P.
2022 Mach 1 HP
Thats correct. I just have heard people chugging along in 4th gear at 2k and them mash the gas and complain they dont feel much power, meanwhile it sounds like marbles in their engine.
Logan@Lethal
Tampa, FL
www.lethalperformance.com
Logan
2020 GT 3.0L Whipple
This is the Ecoboost killer... the amount of Focus ST/RS guys I've seen blow their engine by doing exactly this....
beefcake
Bethel
2018 Ford Mustang
Thats called detonation lol detonation is very bad
