New Steeda Suspension
NoVaGT
Northern Virginia
2019 PP1 GT Kona
  • Thread starter
  • Banned
  • #1
I recently purchased Steeda Pro-Action adjustable shocks, struts, horizontal links, rear shock-mounts, and the Stop The Hop starter kit that comes with their subframe support braces, subframe bushing support kit, and subframe alignment kit. I then had it all installed by a member here that works at a local shop. Shocks and struts were set at one turn out of full-soft.
My first reaction, driving home, was of disorientation. The car looked the same from the driver's seat, the throttle, clutch and brakes felt the same, it smelled the same.
But.....
Every other sensory input was changed. What my butt, inner-ear, and hands on the steering wheel and shifter felt was totally different. This was disorienting at first, and created a situation where instead of being excited in a happy manner, I was excited in a very surprised manner. I was driving with my mouth open, completely surprised with the weird sensations I was getting, in a car I'd owned for 2+ years and was very used to. I called Peter while driving home (member here, did the work) and I'm sure I sounded retarded as I tried to explain what I was experiencing.
The steering is massively changed (more on that later), the ride is firmer, more controlled, and it absorbs road rash with a solid "thump" and almost 0 harshness. And when bumps/dips/expansion joints/etc. are encountered, the car doesn't squirm or need slight steering corrections, it just goes solidly straight ahead. All the rear-end wiggle and necessary steering corrections are gone. Hard acceleration requires no steering corrections, creates no nose-rise, the car just shoots ahead. Braking has almost 0 nose-dive, it just stops. Acceleration out of a corner requires no steering corrections......it's just......weird, like a go-kart.
Then there were other changes;
Driving home I noticed the shifting felt a bit better, but I didn't know if that was just because the trans was completely warmed up. But in this morning's crisp 38 degree weather, I started the car, waited 30 seconds or so, and put it into gear to head to work. ALL of the nibbling and sometimes crunching going into 2nd and 3rd when cold are gone. Completely gone. This is nothing I expected, and very surprising. I won't tell others to expect the same thing, but I'm guessing the subframe alignment kit got something lined-up better and caused the shifting improvement.
The there's the steering.
This was what I noticed first, as the Indy 500 tires do ruin the steering feel a bit. And suddenly the steering was much crisper. Then I checked my PSIs, and found Peter had increased the tire pressures by about 4 PSI all around. I hand't added air since it got cold, so they needed some. This really improved the steering feel, but also pressed home one interesting point;
The car now handles road-rash much better, even though the tires have 4psi more in them. That's a real testament to the quality of the suspension upgrades. Better ride, better body motion control, 0 rear-end wiggle, better shifting, all at the same time. The goal of budget-baller Aston/911/awesome car has been achieved.
Anyways, I would recommend doing suspension upgrades first to any Mustang owner. My cost with labor was about $1900.00, and it's worth every penny. Peter and the folks at RPM Autohause were fantastic, and they're highly recommended.
So.....
Just do it.
Nagare
Ft Lauderdale
2017 Lightning Blue V6
Did you change the springs too or are those still the stock PP springs?
Glad you enjoy the new suspension, it really makes an incredible difference and I love all of my Steeda parts on the car.
NoVaGT
NoVaGT
Northern Virginia
2019 PP1 GT Kona
  • Thread starter
  • Banned
  • #3
Kept the PP springs. Because D.C. roads.
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
Yep, I've always been an advocate of well-researched and developed suspension upgrades FIRST before anything else (except exhaust, haha). It makes the car sooooo much better to drive.
Glad you're enjoying it!
Jigar@Steeda
Georgia
2017 GT PP
So glad you are enjoying the car!!! It's awesome to hear feedback first hand from a customer and how they are almost in a complete different car after having the car for years. Enjoy brother!!!!:rockon::rockon::rockon:
2morrow
DesignR/DriveR/RiceEatR
NorCal Bay Area
Todd
'16 Mustang GTPP
@NoVaGT Congrats! I did a similar overhaul not too long ago and had the same reaction as you.
It was great on the street then I took it to the track... The new set up inspires so much confidence!
I was attacking apexes where before I would manage them. It totally changed the demeanor of the
vehicle's dynamics. So much so that I knocked off 5 seconds from my previous best time!
I understand that not everyone is into the track and auto-x stuff but if you get an opportunity, do it!
Grimace427
NoVA
2011 Mustang 5.0
And to think there is much more left to improve down the line including rear toe links and bearings, adjustable camber links, front LCA(thrust arm?) bearing, lightweight wheels, probably a few more things suspension related. And even beyond the suspension, you can upgrade the exhaust and shifter among many other things.
tj@steeda
Timothy
Awesome - we truly appreciate the support!
Red Turtle
2018 GT
Enjoy and I just cranked mine down to stiff for fun, and wow, she will give you all the feedback you need.
NoVaGT
NoVaGT
Northern Virginia
2019 PP1 GT Kona
One more observation;
I was driving around in crappy, rainy 50 degree weather today, and a few times I was expecting the trans to nip just a bit when shifting from 1-2 or 2-3. And it didn't, it just doesn't do that anymore.
Then I tried a clutchless 3-2 down-shift, and it did it smoothly and perfectly. Then I tried a few other clutchless up-shifts, and it does those smoothly too.
I really am shocked by how much better the trans shifts.
BmacIL
Enginerd
Naperville, IL
Amazing what happens when weight transfer is controlled, and the subframe isn't flopping around.
NoVaGT
NoVaGT
Northern Virginia
2019 PP1 GT Kona
Next is the infotainment system, speakers, maybe an amp.
I'm waiting for the folks in that sub-forum to hit me with some info.
Travis Rhoads
Roswell, Georgia
travisrhoadsphoto.smugmug.com
Travis Rhoads
2015 Mustang GT-Premium-PP-50th
But.....
So.....
Just do it.
great to read this...makes me want to jump on getting this done sooner now...its next on my list..but it sounds like it is a great change to the car.
NoVaGT
NoVaGT
Northern Virginia
2019 PP1 GT Kona
It's a big difference. It drives like a $100,000 car now.
tj@steeda
Timothy
Ready when you are :)
