New gen 3 engine low oil pressure
boostedblue
Atlanta
2021 Mustang GT
Having this same issue, put in a new motor with hellion twin turbos and low oil pressure comes up. Then it shoots to 40-60 as well..
Did you ever find the issue? Could it be the relocation of the oil pressure sensor with the turbo kit?
DrZed
Canada
Cam
2021 Mustang GT PP1 M6
Try an OEM oil filter just for kicks?
Zrussian13
Phoenix
My hellion system worked great for 50k miles before I started having issues with the new engine so I'm sure it's not the sensor location. I even tapped a mechanical gauge in and it was reading the same. Did you put a oem gen 3 engine in your car or was it a built motor?
If you put a new oem engine like me I'm wondering if ford has a manufacturing issue? The car gets oil pressure but not enough for the gen 3 so I'm wondering if it's bypass related. I swapped sensors and bypass valves and no change. I'm going to swap the housing were the oil cooler and sensors mount next. There is a spring mechanism inside of it where the bypass goes. I'm wondering if there is an issue there but I can't find any information on how it functions. Plus with that housing out I'll he able to borescope the passages much easier. If that's not it I'll have to tear it down to dig deeper.
Zrussian13
Phoenix
I always use the fl500s so I can rule that out. I usually run 40 weight oil with the turbos but tried 20 and 30 to see if anything changed buy symptoms are the same.
DrZed
Canada
Cam
Wow… really hope you get this sorted. These worst thing a gearhead can see: low oil pressure.
Zrussian13
Phoenix
Yeah I just need to make time to dive in. It's been 110°+ plus out here for months so it's hard to get out in the garage plus everytime I start to work on it one of my other pos cars break! Hoping to have my truck and honda done this weekend so I can get back on the gt next week.
boostedblue
Atlanta
2021 Mustang GT
No, mines not a oem block, its a built one.
Well, let me know if you ever figure it out, I’ll do the same, thanks!
MuddyPaws
United States
2019 Bullitt
There is one pressure sensor and one pressure switch. The pressure switch should activate the low pressure warning light. You can show good pressure through the pressure sensor and a bad pressure switch can activate the low pressure warning light.
Zrussian13
Phoenix
Is there any way to test the stock gen 3 oil pump gears? I finally got my car back in the garage and should have it torn down this weekend. So far I haven't noticed any blockages so unless i find a bad seal some where once the timing cover is off I'm guessing it's got to be the gears.
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
What brand gears?
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
Stock. It's a brand new oem long block from ford. I have alldata but there's no testing procedures. Less that 100 miles on the engine.
Are there oil restrictiors on the turbos?
Zrussian13
Phoenix
Yes. Hellion sleeper kit. Ran it for 50k miles with no issues. Put a new long block in and started getting oil warning light. Everything is ran the same way it was on the previous engine.
Andy13186
Most companies recommend 5w50 when boosted I think which obviously would increase pressure
