- Nov 30, 2018
- Odenton, MD
- Justin
- 2015 GT Pro-charged
- Banned
I know this has been asked before, but my circumstances are a bit different/dumb. Few days ago I flashed Lunds base tune, car battery died while trying to flash, replaced battery and was able to flash. First start up car cranks over but stalls within secs. Ends up being I forgot I had an aftermarket maf sensor (bought the car 2nd hand) and Lund was tuning for factory maf. Return maf to stock but I forget to seat the maf harness correctly and end up flooding the engine with gas (tried to start a few times both before maf change and after forgetting to seat properly so not sure if I damaged anything) prior to fixing said seating issue.
After all that I finally get the car started. Fires up nicely, holds rpm, no new noises that I can tell of. However, I get a low oil pressure light (didn't get said light when car was stalling, not sure if it had time to check?), I know this could be a tune issue. Car isn't PP but I'm not sure if prior owner had done anything to change that since it does have an aem afr gauge (could have set up for aem oil gauge too at the same time.) Lund has told me they sent me the non-PP tune. Not sure if its cause I flooded the engine with fuel if that could affect oil pressure that greatly, maybe oil pressure sensor just died, aftermarket sensor, something damaged, or tune.
I know this is an easy check, already triple checked dipstick levels and they're perfect, and I would have checked underneath last night if car wasn't lowered and I had a jack handy at my apartment. I know that's a lot but low workload today so my minds racing. Mainly just trying to figure out if flooding my engine with fuel would be a cause for my low oil pressure. Plan to change my oil and filter this weekend and get under the car and check the sensor. Last thing I want to do is drive it and it actually be an oil pressure issue.
