Need help with wheels, spacers.
FreePenguin
Ohio
Donald
17 mustang
I have the following wheels all 4 in 19x9.0
https://voxxwheel.com/wheel/8632/VoxxReplica/Mustang Performance?finishID=9
I love the wheels, love my car now. But I am getting suspvision work done this week, my front end is dropping 1.125 inch and rear 1 inch using suspension from steeda and their progressive lowering springs (getting full kit) struts shocks etc.
my friend tossed out idea of getting spacers for rear or all wheels to make my wheels sit more flush with car.
I don’t know and never done this before, what stance do people go for? Is it fronts backs or all? What sizing do I need if so; and what is the strongest safest spacers?
I want quality. And what would look best set up?
This is my car now before lowering springs are installed. Give me your opinions and my options!
Garage pic is old but shows the wheels space
Nagare
Ft Lauderdale
2017 Lightning Blue V6
Unless you do extended studs too, you'd want an adapter style spacer that is 20-25mm. 25 is what people usually use for the PP wheels, but your specs are a bit different.
You'd want all four wheels because the tuck is going to be exaggerated once the springs are in.
1 old racer
Fontana CA
Will
the min. you can go with pp1 wheels without c'boring the wheels or cutting the OEM lugs is 23mm. 25mm will work with some tires depending on the shape.
FreePenguin
FreePenguin
Ohio
Donald
17 mustang
Here’s my exact wheel specs.
so guide me! What do I need lol.
Everyone wanted like a grand for Pp take offs in my area that was scuffed and beat up, so I purchased these. Would be great if I found something to work with what I have.
These are awesome wheels, and powdered vs paint.
Now don’t know if it matters, but the lugs on my wheels are smaller than oem, I have gorilla lugs, they are a smaller design though
if I go all 4, I can still rotate my wheels just fine
FreePenguin
FreePenguin
Ohio
Donald
17 mustang
Will putting spacers mess with all the suspension work I’m putting on car? Would hate to ruin the 1400 in suspension parts I just bought
Camber plates struts shocks springs sway bars., will this ruin my alignment or no difference once all is done?
1 old racer
Fontana CA
Will
What does the back side of the wheel look like? Does it have pockets casted in between the log holes? If so how deep?
FreePenguin
FreePenguin
Ohio
Donald
17 mustang
ignore the putty stuff in center cap, I use auto car wash and water was being pushed behind the cover caps and causing rust to come out the center later
so I stuck silicone in there to seal it up, worked well. Just nasty behind the cap now.
FreePenguin
FreePenguin
Ohio
Donald
17 mustang
Looks like a little over 3/4 of an inch
FreePenguin
FreePenguin
Ohio
Donald
17 mustang
Some photos of it.
FreePenguin
FreePenguin
Ohio
Donald
17 mustang
I don’t have a level crazy horse, I guess I will be buying one this week. Lol
I was hoping this was a normal known calculation here. I figure being replica- it was same as pp wheels.
Nagare
Ft Lauderdale
You don't need a level to do what Bill was suggesting, just something a straight edge to hold up from the wheel/tire. You want to figure out how much further out you want them to sit. 20mm should bring it to about what I have here. 25mm would be out a tad more. 5mm is about .2".
FreePenguin
FreePenguin
Ohio
Donald
17 mustang
Here I am reading about like anything above 5mm spacers needing extended lugs,
do they make 20mm spacers? What widths are your tires? Mine are 19x9.0 @ 45 offset. Wondering if your suggestion of 20mm would be more or less than your set up.
I love your cars look. Would like to get that.
What product did you buy?
FreePenguin
FreePenguin
Ohio
Donald
17 mustang
I think your rims are factory offset of 35 mine are offset of 45
how does this factor? Does this mean mine are or yours is further out already? Will that mean 20mm on mine will be further or closer inside, meaning maybe I need 15mm or 25mm or whatever to make up for the offset.
Thanks!
I actually don’t know your guys’s oem offset,
Google is telling me random numbers
1 old racer
Fontana CA
Will
I have 23mm on the rear and 25mm on the fronts and they fit perfect
