Need help with Fore Level 2 kit install
Kona 18
2018 Mustang
Delete the 4 way, run a hose from the manifold port straight to the vacuum block, then from the vacuum block to the brake booster. IF the hose on the manifold is larger than the vacuum block hose, use a reducer fitting to make it smaller. Any left over ports you cap
Thoriniv
Fort Worth , TX
2015 Magnetic GT
I'm doing a similar setup but without a vacuum block. What lines need to have a check valve on them, or can someone describe / illustrate how I would accomplish the same thing just with no vacuum block? Planning on finishing it this weekend. Thanks!
Safridi22
Safridi22
Harrisburg, PA
Shobi
GT V8 Blue
I know u mentioned no vaccum block but heres a pic of what i got done today.....i just finished the major stuff.....now just gotta tidy everything up.
