N
mustangrapidred21
PA
Al
2021 Mustang Eoboost Rapid Red
Never mind
Howitzer
NC
flickr.com
Howie
2015 Mustang GT, 2000 Mercedes C280
paint the calipers...without removing the wheel? what the what. To properly paint the calipers, you should remove the calipers entirely, clean them, prep and paint.
KingKona
Virginia
Shlomo
2019 GT
There are some un-stated reasons why you can't remove the wheels, but those same reasons don't stop you from painting the calipers?
Jstang23
Jack
2023 Mustang GT Eruption Green
To answer your question, NO. If you don't remove the calipers entirely, prep them, and paint them properly the paint will fall off very quickly. Our brakes get very hot and if you don't prep them you'll regret it. Also if you paint them with the wheel on you'll get paint on your wheel, and on the rotor causing hot spots to develop on your pads and rotors.
Please don't waste your time, either have a shop do it or just bite the bullet of unpainted calipers.
BIGG_RIBB
San Francisco
Rob
2014 Mustang GT Premium
As others said, take it to a shop and get it done. Either that or buy some caliper covers that are already painted and have someone install them for you. There's a ton of different options for those.
Well.... 🤣
Paint through a spoke, back up or pull forward, apply more paint, back up or pull forward, apply more paint .... repeat until entire caliper has paint covering it... you'll get it done in about 2 hours per wheel, but no guarantees it will look any good....
mustangrapidred21
mustangrapidred21
PA
Al
Can you give me his number please???🙃
ApplesAndOranges
Dare to compare
Michigan
2022 Mach 1
You can successfully paint the calipers without removing the caliper using the G2 paint system. I used them and my paint was resilient for many years. https://g2usa.com/
-but paint them WITHOUT removing the wheels?? Why would you ever want to do that? 5 Nuts and a jacket stand. You need that much.
