My experience Diff lock out BK051 vs Steeda 555-4443
Robottrainer
Canada
2018 Ford Escape. 2020 Jeep Cherokee. 2021 Ford Mustang GT Stage 2 Roush
I have both kits. Looking at them both, in my opinion, the Steeda 555-4443 is the better kit. It comes with both the softer and harder durometer pucks. The pucks have reliefs for the ribs in the oem bushings. The pucks are a smaller diameter than the the BMR kit (a couple of milimeters). It's enough so that it is a light press fit. Several were having a hard time pressing in the BMR units without trimming the od a little.
shogun32
Northern VA
Don't disagree but white line is better again. 😁
Make SURE you add the rear sheath to fix the bolt vs hole match.
Robottrainer
Robottrainer
Canada
I don't think you can get whiteline anymore. The red Steeda's are very close. Yes I made sleeves.
WD Pro
United Kingdom
Lime GT
We should nickname them ‘girth extenders’ - to help you fill the hole … :giggle:
WD :like:
Robottrainer
Robottrainer
Canada
WD :like:
So much that could be said that isn't G rated
J17GT
IL
2017 Mustang GT PP
I'm not sure why people struggle with the BMR inserts. Yes, it's a very tight fit and no voids for the factory bushings. With the help of a buddy and some grease around the bushing, we were able to get them pressed in enough to get the nut on a few threads of the bolt. Then just tightened things down and pulled the insert in the rest of the way. Was not all that difficult.
