Modifying As-Built Data Guide
VicRattlehead
Route66Raceway
2015 RS1 Roush EcoBoost
OK, so pardon another dumb question.
In the Flash to Pass for 5 flashes, where do I insert the A.
And, as example in Police Dark Mode where does the 1 go.
I appreciate the patience. I'm learning.
Thanks.
Line 724-01-01 the second position in the second group of 4 digits
Matthewstorm
NC
Matthew
2021 Mustang GT Premium
Matthewstorm
NC
Matthew
Vlad Soare
Bucharest, Romania
Vlad
2020 Mustang GT 6MT
If you go to the address 724-01-01 you'll see three groups of digits. Two groups of four digits each, plus a shorter group of just two digits.
The second digit from the second group will be 6. Change it to A for five flashes.
Going to the address 726-32-01 you'll find three groups of four digits each. The second digit from the second group will be 0. Change it to 1 to activate the "police dark mode".
Matthewstorm
NC
Matthew
Thanks!
GreenS550
Houghton, MI 49931 Oakland, MI 48363
Bob
2019 Mustang GT Premium 2020 Explorer Limited
What am I missing? I changed the values in Forscan from 0726-12-01 014B xxxx xxxx to 0726-12-10 0163 when I changed my diff from 3.31 (stock) to 3.55. Any idea why the car doesn't apply power properly when I accelerate? Very odd.
In parentheses it says "xxxx=ratio in hex" whatever that means. Any help?
GreenS550
Bob
Oh, this is on my 2016 Mustang GT Manual Trans...
Shearboy
Ky
Donald
2018 GT Premium
Have Forscan downloaded on my laptop running Windows 10 and downloaded the license downloaded but can't open the .key file. What app do I use to open the file with?
Matthewstorm
NC
Matthew
You load the file from within ForScan.
ScubaSteve2020
Dublin
2019 Race Red Mustang GT
You open the key file, in FORScan.
Shearboy
Ky
Donald
2018 GT Premium
Ok so finally got Forscan license to work but when everything is hooked up to the car it always says no ELM connection. Have the same as the one listed in previous posts. (Second one actually, returned the first thinking it was bad) what the h3$$ am I doing wrong?
Matthewstorm
NC
Matthew
Did you restart your computer?
jimmerheck
Vancouver, Wa.
Jim
2016 Mustang GT Cal Special
When you plug in the dongle, does it light up? It needs to be plugged in firmly. When it's plugged in, do you have the car in run mode without the engine running? Have you switched the toggle switch back and forth to see if it makes a difference?
