Modifying As-Built Data Guide
Falk03
Munich, Germany
Falk
Mustang Convertible
Anyone find a way to change US models radio to work with European frequencies?
The US radio only has odd decimal points (107.7 then 107.9) whereas European radio uses the evens too (107.7 then 107.8 etc...)
I think it is this setting:
727-04-01 _x__ ____ __ Switch Radio to Europe 0=North America 3=Europe
templamentis
New Jersey
Mustang S550 EB Convert
Hello guys. Anybody knows is it possible to add sequencing for the hazards and change fuel level alert miles to empty by forscan?
TicTocTach
DFWTX
Clair
2018 EBPP
That's the one I bought for my 2018, but I haven't even plugged it in yet.
Rash
Cary, NC
2018 Mustang GT Magnetic/Showstopper Red, 401A, Active Exhaust
I’m a FORScan/as-built newbie, thinking about jumping in. Couple questions:
- how many of you actually use a battery charger? Is it really necessary?
- have any of you screwed up your car doing this?
- how difficult is it to learn how to do this on a 1-10 scale?
hlh1
Central VA
2019 GT PP1 A10
I use a battery charger while doing this so that I don't have to worry about the system voltage getting low.
I've not yet screwed up my two Mustangs or F150.
I've found this to have a moderate learning curve, maybe 5 out of 10? But it can be leaned if you take your time.
sldghmr
MD
2015 GT PP, 2020 GT PP2, 2016 F-150 XLT
- I use a battery charger/trickle charger because the 1st time I did it on my F150 it gave a low voltage alarm...have made 4-5 changes on the F150 and about the same on my mustang... no more low voltage alarms...
- Have not screwed either one up yet....gimme time though
- Difficulty about a 4...hardest part was dealing with the drivers for the connection cord. If you can swap an intake manifold or change over to long tube headers you will not have problem with this
rubens_5.0
Los Angeles, CA
Ruben Rolon
2016 Mustang GT PREMIUM PP ESS G3 SUPERCHARGED
Yes, this is possible. I did this on mine.
Basically you need to do the following steps:
1)
Get a new bumper cover with the mounting points for the sensors (or drill the wholes yourself and glue the brackets to hold the sensors on the bumper).
2)
Get the sensors and paint them.
3)
Get the correct wiring harness for the bumper. The wiring in the car between the BCM and C405 was already there.
4)
Change the programming in the IPC and the BCM.
I can provide you with part numbers for the sensors and the info for the programming. I fiddled around with the harness myself and upgraded my harness with a used one from some other Ford model. And I bought a new bumper cover.
Hope this helps a bit.
Cheers
Falk
Could you actually get me the programming for rear parking sensors thought i had everything but im missing something please and thank you
Rash
Cary, NC
Can anyone recommend an inexpensive battery charger/tender? Also which is better - float or trickle tender?
Falk03
Munich, Germany
Falk
Mustang Convertible
BCM
726-46-02 xxxx xxx* xxxx Park Aid Feature Present Cfg: 0=not present, 1=present
APIM
7D0-04-02 xxx* xx Parking Assistance: 0=no PDC/PSM/SAPP, 1=rear PDC, 2=rear/front PDC, 3=rear/front PDC/SAPP (NA HMI), 4=rear/SAPP (EU HMI), 5=rear/front PDC/SAPP (EU HMI), 6=rear/SAPP (EU HMI), 7=rear/front PDC with APA, 8=APA Lite, 9=APA Lite Plus (SAPP/POA-10 channel)
--> 1 (not tested)
IPC
720-02-02 *xxx xxxx --> 5
PAM
736-01-01 4450 000B
736-02-01 0400 0400
736-03-01 0600 4200
736-04-01 0000 0000
736-05-01 0000 0000
I think this is all.
Regards
Falk
rubens_5.0
Los Angeles, CA
Ruben Rolon
BCM
APIM
--> 1 (not tested)
IPC
PAM
736-01-01 4450 000B
736-02-01 0400 0400
736-03-01 0600 4200
736-04-01 0000 0000
736-05-01 0000 0000
Regards
Falk
Thanks really appreciate it
sldghmr
MD
Is there a way to get the alarm system to auto-alarm, instead of having to activate it by locking the car by the door handle OR the fob?
Is there a way to add the security feature that locks the gas door and center console? It was a feature available only with one of the optional packages, I think it was the Safe & Smart Package (I found have bungled that package naming...lol).
