Rash
After doing just the BCM change, I tried putting on cruise control while driving and nothing happened at all. It wouldn’t work. After I restored the BCM settings and changed the IPC settings, the cruise icon does come on when I hit cruise on the steering wheel. I haven’t tested it while moving yet I’ll do that today and post back.Actually this is correct. If you disable the Adaptive Cruise in the BCM, there is nothing the IPC can do and it will show these options greyed out. The second setting was to remove these greyed out options from the IPC.
Did you actually check if the cruise control was working by doing a test drive?
