Modifying As-Built Data Guide
MakStang
Greece
www.cellentis.uk
Makis
A 2017 miraculous little beast
Crackerjack17
WV/Maryland
2017 GT PP
So, I have everything hooked up and made a couple changes. But, I've searched and searched, did I miss where to enable "nav in motion"?
GiddyUp15
YMR Member #585
Colorado Springs, CO
Danny
15 GT Convertible
Crackerjack17
WV/Maryland
2017 GT PP
nm_mustang
New Mexico
2015 mustang V6
911 Assist Help
I lost 911 assist after MFT sync2 and NAV upgrade in my 2015 mustang base. Has anyone that has done these upgrades still have 911 assist. Done know if it's a APIM or RCM setting or installed with 3.8 software in car update. I have not found anything doing a google search.
GiddyUp15
YMR Member #585
Danny
15 GT Convertible
This only works for sync 2. I just did this and also the nav mod on my 2015 gtpp. I don't think either mod works for sync 3.
Good to know! I wasn't sure since the two others commenting about it had 2017s.
BULL1TT
culpeper, va
2015 mustang GT, 2001 Bullitt
I had the exact same thing happen. I've tried changing some of the values in the APIM from information that I have found online but have not had any luck getting 911 assist turned back on. Let me know if you find out anything.
nm_mustang
New Mexico
2015 mustang V6
911 Assist Help
I did find though a google search, that I person as able to get 911 assist loaded and functioning by downgrading the Sync 2 software back to 3.7. I have not tried this because I don't have a copy of 3.7.
Synyster06Gates
2016 GT Premium
A few modifications I hope are found...
Enable GT350 Digital Gauges on GTPP (Digital Speedo, Trans Temp, Diff Temp...)
Enable Sport Mode activates active exhaust valve (Allows GTPP to use GT350 active exhaust)
Enable driver seat exit movement for cars without seat memory feature
Enable Track Key (Someone just needs to try it already!)
Enable fuel dump during off throttle in sport mode (Focus RS)
I will definitely be using...
Fogs on during turn signals
Fogs on during High beams
Double honk off during no key exit
[MENTION=14728]GrabberBlue[/MENTION]
Has anyone followed up on the enable sport mode activates the exhaust valve? I'm trying to wire up an OEM like active exhaust kit and if that's the case, it would make everything perfect if the GT has the same body harness as the GT350
StangATX
Project Corrupted Cyclone
Austin, TX
2016 S550 White Corrupted Cyclone
App should be done pretty soon. I got a little bit more time to work on it today. Probably tonight or tomorrow I'll post it up here!
StangATX
Austin, TX
Crackerjack17
WV/Maryland
2017 GT PP
StangATX
Austin, TX
Nice! Well done!! What about the nav in motion code? It works, but says "English selected" evertime you start the cat.
Also, what about just putting enable and disable state in same card, instead of completely seperate?
Thanks! I will add the code whenever I get some time. What do you mean by the same card...? It should show up. Also on top right if you click on the "__" symbol it'll prompt you for a search. When the search is made it'll highlight the word from your search on the card.
