OppoLock
RWD Addict
- Apr 21, 2014
- St. Petersburg, FL
- Sean
- '15 GT, '20 GT350
- Vehicle Showcase
- 1
They absolutely do impact noise. Even the smaller twin turbo setup and twinscroll singles act as mufflers, so say goodbye to that sharp induction bark and crisp exhaust note. The past half-decade of motors coming out of Bavaria have made up for the lack of a complex soundtrack by at least sounding smooth throughout the range, or compensating with "active sound design", which is a pre-recorded engine track (or an actively-recorded track depending on the model) that gets pumped through the speakers. They sound good, but it's heresy to some enthusiasts. It's proof that F/I muddles the end product either way.Small turbos don't have too much of an impact on noise (if any), just listen to any of the german luxury cars. As for blower, I meant turbo; I'm new to the terminology and I assumed forced induction was forced induction.
I don't see how the inclusion of a Torsen diff would make a noticeable difference in low-end acceleration. If traction issues are that bad, then the rate you're accelerating at should feel plenty fast. A diff wouldn't do much to help out in most instances, but more torque would give you that kidney sucking sensation if that's what you're referring to.This is true. I drove a GT/CS which probably didn't have the Torsen. I was able to floor it in first from a roll without any traction issues which to me means two things:
1) Not a ton of torque (torque is what breaks traction, not horsepower)
2) Probably not the higher ratio rear-end
100% agreed.Personally I've always thought that if you want to go forced induction, buy the model that offers it. Why buy a 5.0 not setup for forced induction when you know there will be a model that offers it out of the box.
That's just my 2cents though.
Right, the N54's twin turbos have a huge plateau of torque across the general range of 1500-5500 RPM, which is great for DD'ing, but it's a shame that those little snails run out of breath as soon as you head above that range. Lag is relatively minimal, but the throttle response is still very rubber-bandy, so to speak. Heatsoak is also a huge issue with my 335i. And +1 regarding your supercharger input.Just curious if you've driven the Audi's you highlight.
I haven't, but I have driven a BMW 335 (with the twin turbos) and I own a VW GTI. Both have relatively well respected turbo engines, and both make great torque down low, but both also have horrible turbo lag.
I drove the 335 at an AutoX, which admittedly is about the worst case situation for exposing turbo lag, and it was not a fun experience due to the lag. I think if I owned the car I'd adapt to the lag for track driving, but for street driving it is very annoying. The GTI is similar. Less power overall but the lag leaves a similar feeling of unresponsiveness.
The only time I really like the feel of the turbo is when going up a hill. That's when you have high, steady state load at a low RPM, and the turbo really works well in that case. When you have dynamic throttle application, the lag is very evident IMO and masks the low-end torque.
So, IMO, turbos look good on a dyno and provide good advertising numbers, but aren't very fun to drive due to the lag.
I think the positive displacement supercharger that's mounted right on top of the engine with the integral intercooler is a much better way to get the low-end torque. The Audi Supercharged V6 is a good example.
Anyhow, if I wanted to get more low end, with quick response, that's the way I'd be looking.
-T
Well their TTV8's have low boost thresholds like the F/I motors from BMW, sharing a similar effective torque range from around 1.5-2k up to 5500 RPM, but they're still going to be affected by lag to some degree.Yeah that's a fair point. Price is the main motivator; anything on the market that gives you mustang performance with a turbo costs at least $20k more.
I haven't driven either the rs5 or rs7, I just know their torque curves are flat starting around 1700 rpm or so. Being an engineer sometimes I do let the numbers get the best of me lol.
Direct injection would be rather beneficial for low end improvements (and the fuel efficiency it brings with it would be an added perk). It's one thing that I'm afraid to miss out on by being an early adopter for the S550. I wish that we had some more concrete info on a timeline for upcoming powertrain enhancements.The bottom line is, short of increasing displacement, there's only so many tricks that can be employed to broaden the torque curve (substantially increasing the low end) without sacrificing the high end power too much. I believe all of the things that have been discussed will improve the S550 over its predecessors.
The question is whether it will provide a dramatic enough improvement in low-end grunt that I believe the OP is looking for. We can theorize all we want, but the only way to find out will be to wait and drive it. If it still leaves more to be desired, I think a positive displacement blower will be just what the doctor ordered...
Same here. I keep my 335i in the 2000-3500 RPM range all the time. It's fun to apply WOT in that range, short shifting and just riding the torque wave.I can relate to what the OP is talking about, but have no idea what is necessary to achieve it on the s550, because as many have mentioned we do not have the proper specs/analysis yet.
I have BMW 135is, (3.0 liter w/scrolling turbo).. & have roughly 350ft-lb of torque just off idle at 1,300 rpms..
I hardly ever see 3,500 rpm during daily driving..
I will be waiting for the first DFI V6 FI Mustang. I have no need for 500hp+, when I can have 400ft-lbs of torque at 2k rpms in a turbo stang.
I wish I had more reason to. :( I only do it for the noise since it runs out of breath at high RPM...Do you guys really not take your car to redline on a semi-regular basis? It's good for the engine to get it up there every once in a while, and on the on-ramps makes for a ton of fun.
