MMR Billet oil pump install
Inigo
P2P Engineering
Denver
Alex
2015 PP GT 6spd
I've been trying to find instructions as well....care to point me in the correct direction?
RBS550
RBS550
Port St Lucie Fl
www.youtube.com
RB
2015 Mustang GT
esacteksab
CO & KS
2015 Mustang GT
Says $10.95 now ... might have to do this. Do they download as PDF files, or do you have to make/print your own PDFs (ie, print with Google Chrome)?
I print to file, which in Internet Explorer is XPS, Mozilla/Chrome is PDF.
The site absolutely requires Internet Explorer -- yes. After 5 years, I dug up a Windows machine so I could access this site...
Inigo
P2P Engineering
Denver
Alex
2015 PP GT 6spd
I'll see if I can take some additional pictures when I do this install. I'll be replacing the OPG and timing gear with MMRs.
I will be replacing the TTY harmonic damper bolt, vcgs, front cover gaskets ets.
beefcake
Bethel
2018 Ford Mustang
I always suggest a small mirror to check the alignments underneath as well on the chains!
Inigo
P2P Engineering
Denver
Alex
2015 PP GT 6spd
Underneath the VCTs?
When you line up the cams with the data matrix UP does that set TDC on #1?
Are the timing marks on the VCT and link going to match up?
RBS550
RBS550
Port St Lucie Fl
www.youtube.com
RB
2015 Mustang GT
Others will know more about the specifics than I do. I applied Old School knowledge, while turning the crank in a clockwise rotation I watched the #1 intake valves (passenger side up front) when they opened and on their way closed (compression stroke) I knew that when the crankshaft key made it's way to the 12 o'clock position that would be TDC (top dead center) for #1 cylinder. Never did both of my cams' data matrix face up at the same time. It took several rotations to get the colored chain marks to line to line up with the crank mark cam drive marks, and when they did the driver side marks with the dark links where no where near the gear marks, I attribute this to the chains being so long. I would follow what Beefcake and others say as they've been around these engine many years before me, I'm a Newbie.
Reds197
KC
18 BASE (sold)16 LPF 62mm 16 Whipple 15 VMP MT-82
The data matrix lined up on the 11-14 cars. It is different on the 15. They never lined up for me either.
Inigo
P2P Engineering
Denver
Alex
2015 PP GT 6spd
So once that crank is at 12 and both dark links match the timing gear marks, it sounds like people are essentially just creating there own index marks for the cam side.
RBS550
RBS550
Port St Lucie Fl
www.youtube.com
RB
2015 Mustang GT
That could be true, just remember 12 o'clock happens twice, once for compression and once for exhaust. Have your spark plugs out, and as long as you don't move the crank(if you do put it back to the position you had it in, not by making another whole revolution) or the valve springs try to push the cams you'll be good. I used witeout to mark my drivers side chain & gears, this way if the springs rotated the cams, I'd have a reference point to go back to. I did take the time to make the colored links line up on the passenger side before removing then I used the witeout for the drivers side where they sat at that point. If you look through my pics you'll see the witeout on the drivers side chain & cam gear and the crank gear, which I had to transfer the witeout on the stock crank gear to the new MMR crank gear.
Inigo
P2P Engineering
Denver
Alex
2015 PP GT 6spd
Exactly.
RBS550
RBS550
Port St Lucie Fl
www.youtube.com
RB
2015 Mustang GT
RB.
How did you install the A/C belt?
Believe me I dreaded this but it's really easier than you would think.
Start by going around the crank and turn the belt vertical so it will go behind the crank pulley, then put the belt on the A/C pulley, start turning the crank clockwise while feeding the belt back out from behind the crank pulley.
