MMR Billet oil pump install
Inigo
P2P Engineering
Denver
Alex
2015 PP GT 6spd
What gasket material\sealant did you use?
Mod Mustang Racing
California
www.modularmotorsportsracing.com
Worlds Fastest & Only 5 second Coyote
RBS550
RBS550
Port St Lucie Fl
www.youtube.com
RB
2015 Mustang GT
RBS550
RBS550
Port St Lucie Fl
www.youtube.com
RB
2015 Mustang GT
So what are the modified oil pump specs compared to the OEM pump specs - max pressure and volume output?
These questions IDK the answers to. I changed out the stock due to the powdered metal process of the gears which is prone to failure, to MMRs billet gear design. This is more of an insurance item.
RBS550
RBS550
Port St Lucie Fl
www.youtube.com
RB
2015 Mustang GT
BrazukaV8
Los Angeles CA
Carlo
Mustang gt PP
I'm wondering if anyone know how much are shops charging to install the oil pump and sprocket. When is this a must to install?
RBS550
RBS550
Port St Lucie Fl
www.youtube.com
RB
2015 Mustang GT
IDK, but maybe thru a google search you can find out the time Ford says it will take, this is what most shops go by and X the hrs. by their shop rate. This is one of those jobs where the work is way more intense than the part itself. It's a shame Ford doesn't offer this as an option. Even the CS (Coyote Stock) engine for NMRA doesn't come with the good pump, and racers have lost engines because of it.
And as far as when most others may have a better answer as I'm new to the Coyote, but what I gather is with the addition of a supercharger or in my case the higher rpms. I have a friend that's made 700+RWHP with a supercharger with the stock pump, but he knows he's flirting with danger, one thing that helps him is he doesn't race or beat on the car.
beefcake
Bethel
2018 Ford Mustang
we get 8
Inigo
P2P Engineering
Denver
Alex
2015 PP GT 6spd
Do you replace the front timing cover 3 piece gasket set or did you re-use the gasket and dab some silicone at the edges of the mating surfaces?
RBS550
RBS550
Port St Lucie Fl
www.youtube.com
RB
2015 Mustang GT
Good question. I reused it, but take care in removing the front cove because that sealant that Ford uses doesn't want to let go, that rubber gasket get suck to the cover and the block at the same time....that's some really good stuff.
krahooligan
teach me your ways....
Inigo
P2P Engineering
Denver
Alex
2015 PP GT 6spd
Did you use TA-30 or TA-31 sealant? I'm about to do this install
RBS550
RBS550
Port St Lucie Fl
www.youtube.com
RB
2015 Mustang GT
I tried looking on my phone but I can't find it. I know I got it off of Ford instructions. It comes in a tube like caulking for house windows but shorter, it's almost black in color and has a very short time frame once applied. I know this doesn't answer your question, I can find out after work. It was $ 20 some dollars.
