Missing Engine Oil Temp Gauge on 2019
martinjlm
Retired from GM
Detroit
2017 Camaro Fifty SS Convertible
Pages 89 & 90 are for the "Type 1" gauge cluster (the non-digital). The "Type 2" (all digital) gauge type settings start on page 94. I see no "Oil Temp" setting option under the Type 2 gauge.
Wow. That sucks.
GN34
GN34
Nashville
Clay
2019 Mustang GT
That's the issue with the manual, from page 94 on where it describes the Type 2 Display, it never mentions available gauges again.
I assume the Fuel History graph was also removed from the LCD display.
Not having these features isn't the end of world, but it's confusing to see them cited in the manual. At least I now know my car isn't missing a feature it is supposed to have.
This forum is more helpful than Customer Service or the dealer.
How close is the Engine Oil Temp related to the Cylinder Head Temp and the Water Temp?
db252
Equinsu Ocha
Bay Area, CA
16 GT Premium/PP/Nav
Here’s a pic I have to give you some reference. In regards to my IAT gauge, it reads IAT2 instead of IAT1 like most cars would but I am Lund tuned plus I’ve been idling quite some time before I shut the motor off.
sdiver68
St. Louis
18 GT PP1 10R80 Vert
My 18 non-digital gauge cluster show Oil Temp in the small LCD. However, it typically only displays the word 'Normal', no actual temp.
opengl
PA
2018 GT PP1 400A 6MT
Once everything is up to temperature, they're around the same. But the oil takes a lot longer to get there than water temp, usually 2-3 times as long. You can be at normal operating temp. for water, 190ish, but the oil could still barely be over 100 degrees. Oil temp is what you want to pay attention to with regards to waiting until it's fully up to temp before driving hard.
DLW
Union City, CA
2019 Mustang GT PP2
Just another confirmation, my 2019 PP2 does not have the oil temp gauge either.
GT Pony
Pacific NW
If you press "OK" when it's on the Oil Temp you should see a virtual gauge like below ... that's how the 2015-2017 works at least.
sdiver68
St. Louis
Yes, sure does. I thought I tested that to check for more detail. However, I just retested and you are exactly right. Thanks!
GT Pony
Pacific NW
^^^ BTW ... that photo is of my GT at full operating temperature, and the oil temperature gauge needle is just to the left of center which is 200 F based on what each color zone represents (needle at the middle of the green zone is 210 F).
I then took an IR temperature gun and measured the black oil pan temperature and it was 199 F. So that tells me the virtual temperature gauge is pretty accurate.
Dfeeds
Illinois, US
My 2019 GT PP1 has it with the non digital gauges as well, pictured above. If it's not present then I'd say it may be a firmware bug and a trip to the dealer wouldn't hurt for a reflash. I just don't see why the digital dash, which is just a straight upgrade, would come with less options over the standard.
DavidinDurango
Durango, Colorado
2019 GT
The lack of Oil Temp is a major disappointment! I want to discuss their ancestors sexual habits . . . .
The heated steering wheel is nice, but doesn't make up for it. I am using cyl head temp . . . whoever said that the oil temp lags behind water temp is spot on. Make sure everything is toasty before you mash the foot feed!
Zooks527
2019 KB GT, 401A, 6MT, PP1, S&S, MR, AE, B&O / 2018 Jeep Grand Cherokee Summit
It's interesting how long it takes to come up. On my M235, operating temperature for the coolant is 220F, oil is 245F. The coolant reaches full temperature in about 5 miles / 8 minutes on my drive to work. The oil takes nearly 20 miles / 25 minutes before it does the same.
GT Pony
Pacific NW
Here's a couple of data points I've recorded on my 2015 GT.
During warm-up
Cyl Head = 165F (on center display)
Oil Temp = 140F (just hits the green zone)
At full operating temperature (mellow driving)
Cyl Head = 200~205F
Oil Temp = 200F
DavidinDurango
Durango, Colorado
2019 GT
During warm-up
Cyl Head = 200~205F
Oil Temp = 200F
Thanks for posting this info!
