Missing Engine Oil Temp Gauge on 2019
JJKJ
Iowa
2019 GT350
I was also disappointed with the lack of oil temp when I took delivery of my 19 PP2. I found an earlier thread discussing the issue and one remedy which involved swapping the standard GTPP gauge cluster with a GT350 gauge cluster. The swap replaces vacuum gauge with oil temp. Was plug-in-play; cost was about $250.
el-guapin
LSU - Geaux Tigers!
www.tesla.com
1949 UFO
Be aware that the GT350 cluster does NOT support MyColor. It’s one color.
HoosierDaddy
Randy
True, I probably should’ve included that info in my post.
Yes, based on other posts, some members sneak upgrades past their wives. I know mine wouldn't notice the vacuum gauge changed to oil temp but would sure notice it was suddenly a different color.
767.mph
Phoenix
www.stromspeed.com
Marcus
1965 FFR Cobra, ‘21 Mustang Mach-1
Just picked up my ‘19 PP2 Digi-Dash a week ago and was very disappointed as well. Dealer confirmed this FW does NOT have oil temp.
Such a basic and critical instrument for such a high performance model as this is beyond “just an oversight”. I am wondering if there is proprietary info here or Ford is worried that it takes so long to heat 10 Qts of oil that customers may complain?
Then make it a special request for owners for a flash to update and give to use in real numbers as well, not the dummy gauge. I’ll even pay for the flash. :facepalm:
GN34
GN34
Nashville
Clay
2019 Mustang GT
Would it be safe to assume that when the Automatic Transmission Temperature gauge rises out of the blue sector (120 F), the engine oil is at normal operating temperature?
HoosierDaddy
Randy
Since this post, another member confirm the gauge pack has the different color LEDs inside. It Does support MyColor.
POGGDCOIDH
(Pictures of the GT350 gauges displaying color or it didn't happen).
The new part number that does support MyColor would be nice.
el-guapin
LSU - Geaux Tigers!
www.tesla.com
1949 UFO
POGGDCOIDH
See below....
I was under the impression that the current GT350 center gauge pod(FR3Z-10849-E) does not support MyColor. It’s whitish/grey in color only.
It is white/grey on a Shelby but once installed on a mustang with mycolor option you can switch colors. The gauge does have RGB LEDs inside. I have taken apart already.
https://www.mustang6g.com/forums/threads/changing-center-oil-gauges-lights.103463/#post-2242240
HoosierDaddy
Randy
I don't see where that thread said MyColor actually works with the GT350 center gauges, just that it should in theory because the part has RGB LEDs in it. Will be nice to actually see one working, i.e. changing the colors via MyColor and having them match the rest of the lights controlled by MyColor. And since other members have confirmed the gauges they installed in their MyColor car did NOT change colors with MyColor it would have to take some tweak or new part number.
armykyle1 [HACKED ACCOUNT
Gulf Coast
2018 GTPP premium
I would do the swap on mine today if I could figure out how to make it work with my color.
rome5982
West Palm Beach
2020 Velocity Blue Mustang GT PP1, 401A, 9 speaker system on order
I just picked up my 2020 GT PP1 401A and confirmed that we still do not have the digital oil temperature gauge (even though the owners manual still indicates that it is a selection). Probably the most important sensor indication for a performance car that is pushed to upper rev limits. Unbelievable that Ford does not have that sensor??? I guess I will just use the Cylinder Head gauge.
gmupatriot
Northern VA
2018 Mustang GT (Orange Fury), 401A, A10, 3.55
I have a Nov 2017 build 2018 Mustang GT and it does have the digital oil temp gauge. It seems that a software revision soon after removed that option which makes zero sense! WTH Ford :/
