Magna Ride PP1 Wheel Offset and spacers
Hadelson
Allentown, Pennsylvania
Hugo
24 RTR Spec 3
Car is on order. Looking at options to increase track by 1". This is a PP1 Magna Ride Car. What have others done here with recommendations what works and what does not. This is my fun car not planning on track-just drive with fun.
Thanks
Hivel
NorCal
Mustang GT
Thanks
The Magneride GTs have upgraded front spindles and rear hubs. The magnetorheological shocks were tearing up the standard GT hubs.
So, I think the magneride rear track width is wider than standard GTs. I used 19”x11” rear wheels with a +50 offset and I wish I had gotten +56 offset. IMHO it pokes a little too much. The factory rear PP1 19”x9.5” wheel has a +52 offset.
I used 19”x10” front wheels with a +35 offset. That is perfectly flush with P285 MPS4S tires. The factory front PP1 wheel is 19”x9” with a +45 offset.
Cheers,
Hadelson
Hadelson
Hugo
24 RTR Spec 3
Cheers,
Thanks for information. This is an area I do not know....so the offset is basically the distance from the mounting point inward? So by increasing rim width and less offset, the track actually was wider?
Thanks again
MrWolf
UK - Wiltshire
Tom
MY2018 Magnetic Auto GT
Cheers,
Would the rear track on the Magneride GT not be the same as the GT350 then?
Hivel
NorCal
Mustang GT
That is my guess. But; I haven’t seen any proof of that. All I know is that a common S550 rear wheel size/offset combo pokes more than I thought it would.
I need someone to measure the GT350’s rear flange width and I can compare it to my GT magneride. Or the rear flange width of a non-magneride GT would work also.
Cheers,
Hivel
NorCal
Mustang GT
Thanks again
The wheel offset is how far the wheel center is away from the center line of the wheel. I increased the stock track width by ~1.7”.
PP1 rear wheel outside rim stock distance from rotor hat is
(WheelWidth/2) - WheelOffset
((9.5”/2)*25.4) - 52.5 = 68.15mm
Custom rear wheel width/offset
((11”/2)*25.4) - 50 = 89.7mm
Custom rear wheel track width increase
(89.7mm - 68.14mm) * 2 = 43.1mm
Cheers
Farkel
Cartoon City, Nirvana
Marc
'20 GT Premium PP1, 2012 Jeep JK, 2022 Harley 48
Did you have to get completely new wheels in order to go into a square set up?
If the front and rear wheels are different sizes, it's not "square", it's a trapezoid.
tosha
Canada
Mustang GT PP1
