AMR Wheel Offset Question - Wheel Spacers?
Frankiebass
Frank
2022 Mustang GT Nite Pony
Hi all,
I did a search but was unable to find the answer to my question. I would like to get the AMR Wheels for my 2022 GT from American Racing.
(https://www.americanmuscle.com/black-amr-19x10-2015.html)
I'm looking at 19x11 for the rear which will fit but I want the 19x10 for the front.
The 19x10 have a 48mm offset with a 7.39 Inch backspacing. Looking at other 10" wide rims it seems like I might be able to put an 8mm spacer on the front to allow them to fit. I think. Am i interpreting wheel offset backwards?
Not adverse to replacing the wheel studs with longer ones.
Thanks for your help.
robvas
MI
2011 GT
It subtracts. So if you have a +48mm offset wheel, you end up with a +40 by using an 8mm spacer
You'll want to count your threads, 8mm might be near the limit of the stock studs
Frankiebass
Frankiebass
Frank
Thanks very much robvas. Sounds like I can use the rims I want! Front studs are easy peasy.
DadzMach
2023 Mach 1
I would assume that they are going to be an aggressive fit already and won’t need spacers. If they are selling them specifically for the Mustang and from a place that specializes in Mustangs, I think you will be happy.
robvas
MI
2011 GT
They are listed as 'rear-only' because of the offset. You will generally hit a strut with the tire if you put that on the front, so guys will use a small spacer to get them to clear.
Need4SpeedMotors
Los Angeles, CA
www.n4sm.com
N4SM Team
8mm spacer is not recommended on the stock studs. The biggest you can do to be safe is 5mm.
Ideally a 19x10 +35 offset fits perfect on the front of these S550 cars. +40 offset is ok to run but the wheel won't sit flush, it will slightly sink inside the fenders.
Frankiebass
Frankiebass
Frank
I think a 15mm spacer with 1/2" longer studs should do the trick then. Or maybe a 10mm. I'm obviously not going to find a 13mm spacer. :wink:
Let me know what you think please.
