MACH 1 HP Spoiler
Galvez1978
Spain
Mach1 2021- KTM Xbow RR - 991GT3- G500- Alpine A110R
The wing is not painted or coated in any way. Color is the color of the molded plastic.
And anyone have the code or reference for buy it? My dealer have one but it's gloss black and he want to painted it.
Skye
≈39N
"Skye" Mach1 N2144
My apologies. I forgot: there are two wing types.
There is a Handling Pack (HP) wing, the "high" wing, which is a gun metal Magnetic Grey color.
There is also the non-HP wing, the "low" wing, which is the lower, traditional black Magnetic Grey.
Neither wing is coated or painted. Wings are painted.
Reads like you are wanting the "high" wing. Sorry, I do not have the PN#, but if you describe as above, the supporting dealer should be able to search on "HP" and "high wing".
If your dealer has a black one, it is the "low" wing.
Edit: strikeouts correct what I was wrong about.
IPOGT
Alan
All Mach 1’s have magnetic colored rear spoilers. Big wheels or little wheels, high wing or low wing.
Skye
≈39N
"Skye" Mach1 N2144
Skye
≈39N
"Skye" Mach1 N2144
SROhlms
Missouri
Scott
2020 GT Premium
There is a Handling Pack (HP) wing, the "high" wing, which is a gun metal color.
There is also the non-HP wing, the "low" wing, which is the lower, traditional black.
What is your source on this one? Multiple vendors that deal directly with Ford have verified that both versions are painted Ford's Magnetic Grey (5FM6 or J7) and utilize a specific grey base and satin clear. The OEM spoilers on both the Handling Pack and base Machs have paint code tags under the spoilers that indicate such.
Galvez1978
Spain
I think my low spoiler it's not painted, but i'm not sure at all. How can i know it?
If the HP wing comes in glossy black are any problem if the dealer paint it in grey?
SROhlms
Missouri
Scott
2020 GT Premium
Unless Ford has changed how they were making them less than a year ago, they were simply using the GT350/GT500 high wing (Handling Pack) or the old GT Performance Pack 2 low lip spoilers (non- Handling Pack). You can buy each in gloss black, which is their standard color; however, Ford paints them when used on the Machs.
AvalancheSVT
houston, tx
Douglas
2022 Mustang GT PP1 6spd
i'd really like to see one of these body color matched.
Galvez1978
Spain
Ok! if i understand all rear wings HP or not HP are painted in grey, are nor Grey plastic, correct?
And I must paint the HP rear wing of my dealer he bought the correct reference all wings comes in glossy black.
SROhlms
Missouri
Scott
2020 GT Premium
Yes, all rear spoilers are painted by Ford, but only for use on the Mach 1s. You could not buy them painted that way, but rather only in gloss black. As of several months ago, Ford had them available painted for very direct companies that they dealt with. For example, Herrod Performance in Australia verified that Ford paints them for Herrod, but that the spoilers were not available that way from US dealers or vendors. Even body shops here in the US were having to paint them on early wrecked Machs, although that may have changed. As of a couple months ago, Ford did not even have a part number available for the Mach-specific painted version. Even Ford parts sites and dealer's service departments that could look up the parts showed the number for the gloss black versions as being Mach 1 parts, which is obviously incorrect. That may have changed by now.
Galvez1978
Spain
Yes, all rear spoilers are painted by Ford. As of several months ago, Ford had them available for very direct companies that they dealt with. For example, Herrod Performance in Australia verified that Ford paints them for Herrod, but that the spoilers were not available that way from US dealers or vendors. Even body shops here in the US were having to paint them on early wrecked Machs, although that may have changed. As of a couple months ago, Ford did not even have a part number available for the Mach-specific painted version. Even Ford parts sites and dealer's service departments that could look up the parts showed the number for the gloss black versions as being Mach 1 parts, which is obviously incorrect. That may have changed by now.
Thanks!
And other thing, you know which it's the reference for the rear splash guard kit of the Mach1 HP?? I thought it's the same of the GT500
SROhlms
Missouri
Scott
2020 GT Premium
Thanks!
The splash guards that extend off the rear wheel openings and tie into the rear diffuser? The list I curated shows them as the following :
KR3Z-6328371-AA Left
KR3Z-6328370-AA Right
Galvez1978
Spain
Thank you so much!
