M1 HP Removable Lower Splitter Task
Knockdown
Greg
2021 Mustang Mach 1
I’ll be installing some dual rate springs in the near future, so I would like to run with the lower splitter on for track days, but take it off if I’m heading out for a road trip.
The first step was lower splitter removal, a small burr bit on a drill to provide a center for a pointed air hammer bit worked the best to remove all of the plastic rivets.
I ordered some M5 aluminum rivet nuts, M5-20 nylon machine screws and a M5 rivet nut wrench style install tool off of Amazon to replace the plastic rivets. I added a large fender washer to the install tool in order to get some pressure on the spacer.
Edit: Read another post where another gentleman used 5mm well nut to install the lower splitter, he mentioned they worked good.
Reattached the lower splitter. The “Nylon” screws from Amazon were very fragile, I snapped a few with just a T handle Allen wrench, I’m going to have to rethink the fasteners, but it’s back on.
RobZ71LM7
Louisville, KY
Rob
2021 Mach 1, 2019 F-150
Very interested in this mod. Had a chance to mount and dismount? Just curious any reason why you went aluminum versus plated steel?
WCRookie99
Illinois
G
2021 Mach 1, 2007 FR500C, 2022 LH5
Actually, great start. This removable lower splitter needs to be a "kit"
Knockdown
Knockdown
Greg
2021 Mustang Mach 1
Yes, I did take it off to remove the broken plastic M5-20 screws and replaced all with M5-16 stainless button head screws. I chose aluminum rivet nuts since it’s a plastic base material and the nuts collapse easier.
BTW, just installed the Steeda dual rate springs and they are sweeeet!
RobZ71LM7
Louisville, KY
Rob
Thanks for the details, I’ll have to do this to mine.
Knockdown
Knockdown
Greg
2021 Mustang Mach 1
Let’s see some before after pics! And height measurements!
Not sure the car has totally settled but after one 30 mile local trip to bed the brake pads, there is about 4.25” clearance to the lower splitter. The cornering and braking dive is greatly improved without compromising the normal ride quality.
SloppyTX
Ft Worth TX
Marc
22 Mach 1 Race Red
Which Rivnut style did you end up going with? Thinwall etc.
Coastal-Mach
Wilmington, NC
Anthony
2023 BMW M440i, 2026 GMC Denali, 2021 Jeep JK
These are the ones I ordered. Install next week
Zelek
Hutto, TX
2021 Mustang Mach 1
I was thinking about tackling this next when its not 103 outside almost every day. I don't remove my splitter but if I ever needed to, this is the way to do it and it looks very clean.
2022 Mach 1
Brentwood ca
Cameron
2022 Mach 1...2014 Mustag GT whipple supercharger
Have you experienced any issues with losing any rivnuts with the plastic expanding on hotter days and the on/off action of the lower splitter? I love this idea just curious if it will stand the heat and removal/adding.
Knockdown
Knockdown
Greg
2021 Mustang Mach 1
it’s working out good for me so far.
Btw, link to the rivet nuts…..Link
