Ackbar00
- Jan 18, 2021
- Dayton, Ohio
- Paul
- 2020 Mustang GT / 1969 Mustang 302
I have been a bit disappointed in my Long tube install and tune every since I got them. Had a local shop do the both. From a power standpoint, I am perfectly happy, it picked up 51 RWHP.
For starters, the headers: They’re LTH brand and hit the steering shaft on right hand turns under pretty much any sense of acceleration. While not moving, they do not come in contact at all. Kind of surprising how pretty much everything transitions with such light power input. It barely touches, but I can feel it in the steering wheel and I can see a light mark on the headers where it has touched. Anyone else with a 2020 GT and LTH headers have this issue?
Next the A10 tuning: Pretty sure my tuner had only tuned manual coyotes (used HP Tuners). I have read how happy people are after they had their A10 tuned and my experience has pretty much been the opposite. I do want to state, that under WOT, there are no issues. Shift fine and runs great. Also, no issues using the paddles.
Pretty much looking to hear what others with A10’s and their tuned experience has been. I would consider a re-tune. Would want a Flex tune with an A10
- All the Sport drive modes now feel like it’s in normal drive. It will skip shift and try to get to the highest gear ASAP. When stock, it would hold each gear out just a little longer like you would expect a sport mode to do. The tuner said he only change the “Sport” mode and none of the others. However, each of them (Sport, Plus, Track) all do the same thing.
- When I took it to the strip. I could only race it in Sport mode, but still had to take the traction control off. I tried to do a burnout mode in Track, and the stability control went nuts. Had to put it back into the Sport mode. That normal? I forgot there was even a Drag mode. Would that have allowed the burnout?
- While cruising around 60 MPH in Sport, the car will jump from 9th to 10th gear consistently. I can only assume that is something in how he programmed the transmission. Never did that when it was stock.
