LT’s or MAK high flowdeletes
jd_cobra
Josh
2022 Mustang GT Dark Matter Gray
For a NA car, is getting LT’s even worth it? Or would the high flow MAK cats be sufficient for decent HP gain?
Stephen@lethal
2020 Mustang Gt500
Yes I would say it is worth it for the headers alone. They are proven to make decent power for the buck even on NA setups. If you have any questions about the different brands, feel free to shoot me a message anytime. lethalperformance.com
beefcake
Bethel
2018 Ford Mustang
At the price point of some of the headers we carry in stock you're getting more bang for your buck, even n/a. Then if you ever add boost a LT is going to flow better than the OEM header and high flow cat setup. Hit me up and we can get you dialed in on a set for sure; have a few options in stock ready to go.
Feel Free to DM me or call with any questions.
Terry "Beefcake" Reeves
Office - 855-TBR-RACE
Owner Team Beefcake - 20+ Years Experience
Deal Directly with the boss, no pushy sales guys!!!!!!!
https://www.beefcakeracing.com - Your Forced Induction Specialists
#beefcakeracing #teambeefcake
Salty
Miami
2015 5.0 MT-82, 2019 5.0 10R80
IMO its not even close to worth it when NA
So would you suggest the high flow MAK cats? I was thinking this too since the cost is generally less the LT's and install would be easier/more affordable.
Andrew@Lethal
West Palm Beach Florida
Andrew
It is for sure worth it to do longtube headers. We sell all the brands here at www.lethalperformance.com! Please feel free to give us a call and we can talk to you in detail and get you the perfect system for your needs! 1.877.253.8425
Andy13186
no I wouldnt change anything from the stock manifolds personally.
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
There is a gain with LT's. It is not as good as back when we had log manifolds. The peak number might not look great but avg power will be worth the hassle.
Dave2013M3
El Segundo,Ca
2024 BMW M2 G87 6MT Toronto Red, 2025 Ford Bronco Badlands 2dr. 7MT
To be frank it depends on where you live if they are worth it or not. In Cali with the way smogging is going I would say no. You live in Texas and if you can get them installed for a decent price or do it yourself I would do it. Question is what are you going to do for software? A lot of tuners won't shut remove the code for inefficient catalyst, something to think about.
jd_cobra
jd_cobra
Josh
Im in Texas. Why would I need to shut the cod off for high flow cats?
OnThree
2015 mustang GT
Headers will get you max 10hp over cat deletes, not worth the price or headache of install unless you go boosted and even then I still wouldn't.
Don't take advice from people trying to sell you something either lol.
OnThree
2015 mustang GT
You'll fail inspection in Texas for having no cats. Your car will throw cat efficiency codes unless your tuner turns them off which will then make you fail for system not ready. You'll have to add the cats back and then run a tune with your O2's turned on to pass or run non foulers.
I ran the mak cat deletes with non foulers and passed on my 15 FWIW.
jd_cobra
jd_cobra
Josh
that’s why I wanted to go with high flow cats instead of an actual delete.
I didn’t think that would throw a light but I couldn’t remember.
OnThree
2015 mustang GT
Pretty much all the aftermarket cats will still throw an efficiency code except for the kooks green cats if I remember correctly so there's that also.
Aftermarket cats are generally crap compared to OEM
blue5.slow
Jack
2017 Mustang GT Base, M/T
nope. Not worth it. You'll get maybe a 7 ish hp increase with high flow cats. Longtubes yield bigger gains and it's worth the money in the long run
