Poppacapp
Yep.. the car takes care of it all automatically.And the car will automatically calculate for that with the Lund ff tune ?
It should adjust really quick.I also just got a flex tune. I'm on my second tank of e85 and ran it down to just a couple miles to empty. I thought it was supposed to richen up but the afr is staying 14.5. When is it supposed to adjust?
14.5 at wot?I also just got a flex tune. I'm on my second tank of e85 and ran it down to just a couple miles to empty. I thought it was supposed to richen up but the afr is staying 14.5. When is it supposed to adjust?
I think he is talking about idle and seeing 9.6-10 for E85 vs. what it was for 93.14.5 at wot?
Make sure you have a flex fuel tune, email Lund to be sure. Something isn't right if you have e85 in the tank and your seeing the same readings as 93. Should adjust after 5-10 mins of normal driving. A/F should be 10.2-10.4 or so at idle with e85 (assuming 100% e85)I also just got a flex tune. I'm on my second tank of e85 and ran it down to just a couple miles to empty. I thought it was supposed to richen up but the afr is staying 14.5. When is it supposed to adjust?
That's is super rich. Is it normal for e85?Make sure you have a flex fuel tune, email Lund to be sure. Something isn't right if you have e85 in the tank and your seeing the same readings as 93. Should adjust after 5-10 mins of normal driving. A/F should be 10.2-10.4 or so at idle with e85 (assuming 100% e85)
Do you have the Nguage? And if so are you reading AFR off it? From what I understand, once the tune flags for E85 then lambda will adjust to E85 ratios. Check your AFR on the dash, you will see the difference.That's what I thought. I didn't want to seem a complete moron when asking them. I'm going to send them an email. Thanks for the info, guys.
yes in fact the highest your ngauge will show is like 78% alcohol. It'll get to the last 7% just in fuel trim adjustments.And the car will automatically calculate for that with the Lund ff tune ?
Yep, perfectly normal. E85 takes approx 30% more volume then 93. For straight e85 that's not rich.That's is super rich. Is it normal for e85?
