Long gearing?
Shibaman
Elk Grove ca
2019 Bullitt. BAD GRN
I am new to the Bullitt. I have a 64 1/2 k code mustang. Had a 15 PP mustang with good mods i sold to buy my Bullitt. My 15 had short gears to shift a bit. Real fun...pretty fast.
Why does the Bullitt have such long gears? Not the best for 1/4 mi....but very nice to drive on twisties....Only need 2nd and 3rd gear. Ideas?
OldPhart
Rochester, NY area
Bruce
ā€˜05 GMC P/U, ā€˜17 Impala, 19 Bullitt
Probably folks donā€™t buy the Bullitt to quarter mile it. That is a lot of extra money when you could use the basic GT. Also the car is maybe designed for older folks who can identify with the original Bullitt movie. If this car had been specifically geared for the drag strip I probably would not have bought it. Personally I would have been happy with 3.55 gearing instead of the 3.73 so Iā€™m at the opposite end of the spectrum from you and perhaps from most others...
Brazos609
2015 GT Premium PP Recaro
The Bullitt has the same gearing as all 18 and up 6-speed GT PP1 models, 3.73 rear end with the same transmission ratios, even the same diameter rear tires.
Shibaman
Shibaman
Elk Grove ca
Hmmm....3.55 gears would have made in longer. Been thinking that with these gears....not 1/4 mi. But to drive hard at high speed. My favorite rd is a 2nd...3rd rd.
hiccup
Kentucky
2015 Mustang GT black base PP RECAROS
op..I hear the '18/19 got wide ratio trans..and your '15 had the close ratio...would be enough to feel like taller gears I guess..?
Shibaman
Shibaman
Elk Grove ca
My 15 did have close gears.... I liked them like that. Got to shift more
The Rooster
earth
2017 GT350
Lots of power on tap, wide powerband, plus a sky high redline make long gears a good choice. Youā€™ll get used to it.
GreenS550
Houghton, MI 49931 Oakland, MI 48363
Bob
2019 Mustang GT Premium 2020 Explorer Limited
MPG. 1 less and it would have the gas guzzler tax
Shibaman
Shibaman
Elk Grove ca
Ha! Put gas in the car and drove 30 mi to get to salmon falls dr.....twisties. 23 mpg on the freeway. On salmon falls...2nd...third gear....18 mpg. Not bad considering
Shibaman
Shibaman
Elk Grove ca
My favorate twisty rd to drive on is salmon falls. Runs from folsom in ca to hwy 49. An amazing rd with curves. A favorate for sports cars....and sport bikes.
The bullitt runs in 2nd....3rd gear. Very different power band. My 15 stang was a 2..3...4 gear.short gears. That said...it had about 1000 rpm less usable power range. At 6500 rpm it was done....shift to another gear. Very different cars.
Pky
Orange, NSW
1989 Ford Falcon XF Ute, 2016 Ford Mustang GT
Iā€™m totally jealous of your 3.73s. Australia Bullitts have 3.55 gearing and itā€™s my only... slight annoyance of the car. 2nd gear pulls to 132kph (82mph) and 3rd goes about 200kph (125mph). Sadly I donā€™t get to hear the top end of the rev range that often. My 2016 GT auto ā€œonlyā€ did 165kph (102mph) in 3rd.
Mustang_Lou
Toronto, Canada
2020 Mustang Bullitt
I suspect the OP is referring to transmission gearing not axle ratio gearing as I've ready the same comment from others including @Bullitt
I actually wish my first gear on my '16 was longer - I feel it's there to do burnouts only and sometimes actually start in second.
DuRsT
2020 GT500 - 2006 GT Convertible
Common complaint on the 18+'s.
I drove a 2015 and the trans gearing makes a massive difference. I'm personally planning on moving to 4.09's when funding allows.
tom_sprecher
Living Race Car Free
Marietta, GA
2016 GT Premium PP 6MT Race Red
I love the close ratio box in my '16 with the 3.73 rear axle. So much to choose from. I can get 27mpg on the highway, and cut switchbacks all day long in the North GA mountains. :like:
