Loaded tune now have code
Jhonda
Nc
Jason
2018 mustang gt pp1
I loaded a new tune after getting a new intake (jlt). After I loaded it I got a code p163f transmission is block corrupted not programmed. Now the car will not shift and the cooling fans will not come on. My tuner says I need to take it to Ford to have the original tune put back in it. I tried to do it with the ngauge I have but had the same code. Anyone have this issue before, if so what am I looking at as far as repair bill or maybe a easy fix? Thanks yall
Rapid Red
Woodstock GA
Greg
Tuner, cannot restore the original code, that's awful ?
Is the TUNER( :question: ) going to foot the bill ? The Tune corrupted the factory tune seems to me. It is his responsibility to reverse/remove his tune.
Confucius say: uphill battle on horizon.
Bummer good luck..
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
Puddintane
'17 S550
Why ? You should be able to load the stock tune yourself. Who's the tuner ?
WildHorse
N/A or GO HOME
Puddintane
'17 S550
Ask Brandon if there gonna cover you warranty. Cause frankly thats BS. Also now for the really bad news. LUND apparently encrypts the PCM so Ford can't do squat.
FreePenguin
Ohio
Donald
17 mustang
I tried to load the stock tune something it’s not working with it. Brandon from Lund told me he seen it twice in six years
its possible, very rare, but something could of gone wrong, a bad write, just bad luck or maybe power level was low, something wrong w pc or module something could of gone low on power or something like that.
ive had like 100 bikes flashed, with friends etc. one guy same process as rest of us but he had a completely bricked module.
Andrew@Lethal
West Palm Beach Florida
Andrew
Perhaps there was some miscommunication about what transmission you have? Maybe they thought it was a manual transmission?
Hammerdown
Oklahoma
David
2006 F150 Screw 4x4
Well I'm following this closely. if things don't change around a lot for the OP I'm going to stay far away from Lund.
Sounds to me like the tune corrupted the original file like somebody else said otherwise it should let him retune it to stock.
vanquishvzla
Jacksonville - FL
2015 Mustang GT 50th anniversary
Pretty sure you bought a used Ngauge, when you updated the device, probably uploaded the previous owner info and his car was manual.... how do i know? it happened to me when i installed the JLT... i was running the canned 93 tune, i changed the cai and when i updated my device, it pulled the previous car for some reason instead of mine.
Yes, there is no weird drama or anything from the tuner... it was your mistake for not paying attention... i did the same shit lol.
Have the car towed to ford, have them reflash the car back to stock... your car think it's manual and that's why the transmission is not shifting. not a big deal... i got mine done, and TRIPLE CHECK you have the right info in your device... ford will let you upload your tune for the JLT before leaving service because without it, the car won't run (it will die at iddle with the JLT without tune)
WildHorse
N/A or GO HOME
Puddintane
'17 S550
If he uploaded a lund tune and cant load the stock tune and LUND encrypts the PCM.. Ford cant flash shit.
Jhonda
Nc
Jason
2018 mustang gt pp1
No it was new bought it over a year ago. I have switched tunes back and forth several times from e85 to 93. Never had a issue before.
gadgtfreek
Fairhope, AL
Jason
2021 GT Premium Shadow Black 10spd Auto
Eeeesh. Exactly why this Friday my lund/ngauge is flashing back to stock and then loading the new Wengerd tune...
vanquishvzla
Jacksonville - FL
mine was an sct X4, i had the car tuned before and zero issues, but for some reason, when i updated the device, i pulled the info from the previous owner. MY car lost all the programing for the auto trans, that's why ford had to re-flash the whole thing in order to install the transmission software.
now, if it was brand new, and they send a custom tune, then yeah, they fucked up the programming and did everything for a manual car instead of an automatic
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
As long as he can flash the stock tune, even if corrupted Ford can flash it.
