Hack
- Nov 26, 2014
- Minneapolis
- Mustang, Challenger
My assumption would be that you would leave Ford's "limp" programming in place, so heat failure would not be a concern. However, there could be another failure based on your engineering of the system, or the failure could be completely unrelated and Ford gives you grief about having put an aftermarket cooler on the transmission and denies you warranty coverage. I'm not trying to insult your ability to design a system; I just tend to be a risk averse type of person and I feel there are a lot of things I, for one, don't know.Can you specify what you mean by warranty claim? Do you mean a failure due to heat from not being equipped with the factory cooler, failure of the aftermarket cooler allowing heat to damage the trans, or failure of the cooler directly causing damage to the trans?
If yes to any of the above, I doubt any of that would be covered under warranty anyway as failures on a racetrack would be cause for warranty denial regardless if it was timed or not because you wouldn't be able to prove it wasn't. Likewise you could also simply say you weren't on a racetrack to begin with and the dealer wouldn't be able to prove otherwise either, in which case the aftermarket coolers wouldn't really matter anyway.
Here's a go; it's not really an FMEA, but just some risks I can think of off the top of my head. If I were designing a system for cooling the transmission, I would be worried about:
- Ending up with too much or not enough fluid in the transmission due to the lines and cooler being higher or lower than the transmission. This could happen when the pump is on, or when it is off, or all the time. It strikes me as being more challenging to get the proper fluid level with the additional parts in place.
- The flow of fluid in or out of the transmission interrupting the designed circulation of oil inside the transmission
- The cooler making the transmission run too cold during street miles and causing a shift harshness problem
- Same issue causing premature wear of transmission internals
- Heck, if I designed the system I would even have some worry about a line coming off or melting on the track and causing me to spin out. Adequate care should prevent this, but heck, I'm a worrier.
Not saying it can't be done, but I would want to design a solution and install it on 10 cars and drive them around in various conditions for 50,000 miles and then rip them apart and examine the pieces to make sure the solution functions properly. That isn't possible for me to do, obviously. That's why I'm really hoping I can buy something from Ford.
