Lean code both banks after clutch replacement HELP
DevinN
DevinN
Ohio
Devin
2018 Mustang GT PP1, 2003 Mustang GT
And it was running normal before the clutch change right? Or atleast that you are aware of? Very strange indeed.
No issues at all before the clutch went out. Car ran very strong.
Garfy
Utah
Gary
Way too coincidental that it's lean after you changed clutch. Something got pinched.
The grille (depending on what grille) being changed paired with that intake can cause MAF turbulence but usually only at highway speeds and very minimal. Not something that would cause a lean condition at idle. Sheepdog is probably correct here.
In my career as an auto technician, I always told the guys that if something happened AFTER you "repaired" or did work on a vehicle that wasn't there before, recheck everything you did because something you did caused the problem. Don't look for things that weren't touched (ie. don't blame the MAF sensor, A/F sensor, fuel pump, etc. as it's too much coincidence that they would suddenly fail after you did a particular job.
DevinN
DevinN
Ohio
Devin
I would agree with this as well. The only issue is I do not believe there was any vacuum lines or that sort of thing that I messed with while doing the trans. I’m thinking when I took the trans out, the engine tilted back slightly. This could have possibly caused a vacuum line to come disconnected or crack right? I never removed the headers, and the mid pipe is tight on the headers.
HKusp
Hampton, Md.
Jason
I do have the vacuum gauge on the car. Do you know what the vacuum gauge should be at or what I should be watching for in terms of the vacuum gauge?
He means boost. If you have a vacuum leak, the boost will certainly be less than it was with the same throttle input because boost will be pushing through the leaking area. Vacuum could be affected as well if it's a straight up leak, but sometimes at low vacuum or low boost, a leak can seal itself if its where there are rubber connections not tightened or a rubber/silicone hose with a cut it may take a certain amount of positive or negative pressure (boost/vacuum) in order for it to open up the cut.
DevinN
DevinN
Ohio
Devin
This is during a smoke test. I do not see any smoke coming out at all. These 2 lines that connect to the CAI do have smoke that comes out of them. I am assuming this is normal. Is anyone able to confirm this?
DevinN
DevinN
Ohio
Devin
Sorry as i’m not super familiar with the usage of the word ā€œboostā€. I’d always assumed it had to do with forced induction; turbos and superchargers. What does it mean in this aspect?
HKusp
Hampton, Md.
Jason
So, boost is positive pressure, like blowing up a balloon, and vacuum is negative pressure or suction, like a vacuum cleaner. Forced induction creates boost in the intake system, measured in pounds of pressure (in the US). It's forcing air and fuel into the cylinders. More air (containing oxygen) and more fuel creates more power. It's how all forced induction works. If there is a leak on the intake side, you are losing boost.
Whitedevil95
Temecula, CA
J.P.
2022 Mach 1 HP
When people are talking about pinched wires they are talking about the harnesses that go up by the bell housing and behind the intake manifold. Not the direct O2 sensor wiring. Its easy to smash or mess up wiring while people are manhandling the transmission back into place. Just FYI thats what they are referencing, the harnesses and bundles of wire that are up top.
DevinN
DevinN
Ohio
Devin
https://datazap.me/u/devinn/logs/cmoohe13v000al206xfuxkq71?channels=1&sizes=100&sc=1
I've done a lot of disconnecting and reconnecting vacuum lines and looking at things that have been recommended through this forum. It seems to be better from what I can see, but I am not all that great at understanding the numbers I am looking at and directly comparing STFT to LTFT. Is anyone able to look at this log and let me know if I seems like I fixed whatever the issue was? (I just did a KAM reset and the car has about 10 miles of driving since that point when I did this log)
