Angrey
- Jun 21, 2020
- Coral Gables
- 2016 GT350
The tune will run the motor at the edge of knock. With higher octane (knock resistance), that edge is a little more timing advance, which results in more power and more torque. When the fuel is a little on the crappy side, it'll back off a little timing to keep it out of knock, so it'll result in a little less power and torque.Right, but if it’s already not knocking and under the same ideal conditions on 93, how does it tell the difference between 93 and a higher octane. That’s what I’m not understanding.
And even perfect 93 knocks when in certain conditions. If you have an NGuage you can see the computer/tune pulling timing out when the car is at lower rpms and full load. The only time you'll ever notice knock (without an nguage or data logger hooked up) is when the fuel is so bad that it's exceeding the tune's limits to withdraw timing (so it's still knocking).
