Jack points
stanglife
Jeff
1993 Coyote Coupe
Heard that before..
I am not going to say a word about 350 or R that will be negative until the day I own one. I promise.
/thread.
Tank
9/11 - Never Forget
Above the Notches
G0853
What's interesting with the OP threads and posts, considering all the genuinely helpful information provided, is that there's one, lonely 'thanks' given.
MCarsFan
East
2017 GT350
Now that is not cool.
I say thanks so many times. If you are joking, its not funny.
If I wasnt clear, THANK YOU for all the help.
icormba
San Jose, Ca
Jeep SRT8 / GT350R / FocusRS
It does not face the front of the car, its rear facing right next to the tranny, huge yellow plug, even you wouldnt be able to miss it.
Jesus dude, please don't post another thing until you read your owners manual, you are seriously sounding like a grade A dunce right now.
Don't forget to mention to use one of those Big 6 quart drain pan's! ;)
xXANCHORMONXx
SF CA
2016 GT350 Track Pack
I'm just here for my daily dose of stupidity.
I meet people like you on a weekly basis, completely useless.
Unless it's spoon fed or drawn out in detail you just can't figure it out on your own.
Next Phase
NC
Mopar
He should take note....the 6 qt pan is critical for the job.
CSL
WA
16 GT350
Without jacking rails you will damage the underside of your car over time, it's inevitable.
Order the rails and wait until they arrive to change your oil. It's the right thing to do.
Not true. I use a jacking insert and my jack itself never touches the car.
Next Phase
NC
Mopar
I've been using hockey pucks for years... Especially on pinch welds or on frames that I don't want marred. YMMV
stanglife
Jeff
1993 Coyote Coupe
A) I didnt say anything negative
B) I own the car now
C) you broke hat promise dozens of times while you trolled relentlessly for months = I don't trust you.
Yetitime
Tracy, CA
Brad
2016 GT350 Tech Pak
What do you mean? Aren't you jacking from the frame of the car in the underneath? Are you saying you will be damaging the frame? Is it just scratches/visual or do you think the area will eventually be bent etc?
Do the same rails work with this car as the ones that work with the base mustang?
The Steeda jacking rails work on the 350, unscrew the bolts, and re-bolt, takes all of about 10 minutes. It will take more time trying to get the car up on jack stands than to do the install.
The pinch welds do work, there is a cut out that you put the jack in, the problem is that over time jacking up from this point will start to bend the pinch welds, its just the way it is. The jacking rails allow you to jack up the car from any point and can raise if from center and lift both front and rear wheels off the ground.
Make sure you get a low profile jack.
GT_Dave
NE Illinois
1970 Mach 1 408EFI , 2016 GT350
The qualifier to my statement was "over time" and it is very true. None of you have had your GT350's long enough to effect the pinch welded areas by jacking your car using a block or insert. I have an identical situation on my Lincoln LS that I have had for 14 years and always using jacking inserts on that car. Over time the pinch welds will get distorted and the paint will get stressed to the point those areas will deteriorate.
The point I am making is that jacking rails are a superior choice, much more convenient, faster to raise the car and will not result in any damage over the long haul.
