Is there a coolant drain bolt on the engine block
An7h0ny
Anthony
2017 mustang GT pp1
Hi all is there a coolant drain bolt on the engine block and where and what it looks like? This is for 2017 gt PP1. Thanks
GTP
Deutsche Pony
Indy
www.BambergAudio.com
Philip
I don't know the answer to your question.
But stating the obvious, there is a drain cock on the passenger side lower corner of the radiator. Would require removing the belly pan (or front clip with pan assembly) to access it.
Maybe your question is to avoid that.
On a Coyote -
Check on the driver's side of the block, up by the oil filter housing. There might be a recessed plug/hex fitting (ALLEN KEYED) that sits flush or just about flush with the block. This location may vary by Coyote Generation and/or Variant. Use a bright LED light when looking for these plugs. If it's not by the oil filter housing, look along the block on driver side near any expansion plugs or back by cylinder 8. I'm not sure if one exists on the passenger side (or elsewhere on the block). If there is another coolant plug/fitting, it should be same type as the one found on driver side.
An7h0ny
Anthony
2017 mustang GT pp1
I was hoping to mostly flush by draining radiator and the engine block past the thermostat without removing the thermostat. I'm thinking radiator bung only drains the radiator.
EFI
Masshole central
5.Br0
You could also remove the water pump to drain most of the engine block coolant.
