how does one drain the coolant fluid? (the pink stuff)
ALLSTOCK
DMV
2012 Honda Accord LX 5MT, 2019 Mustang GT Premium PP2
popped my hood to change my battery and noticed that the fluid reservoir is showing the fluid level well over the max line.
should i be concerned?
how would i drain out a bit?
I was thinking of just using like a turkey baster and sucking it out
Nagare
Ft Lauderdale
2017 Lightning Blue V6
Should be a drain plug at the bottom of the radiator, a hose going in towards your intake manifold, or you could do it by the thermostat housing. The turkey baster idea sounds the easiest to me though.
Are you reading it while the engine is still hot or is it thoroughly cold? It expands when hot.
ChromaticGrey
Nevada
Grey
2017 Mustang GT PP1
If the engine was warm when it was over max i wouldn't worry, that's normal Check when cold.
If it's over the max line significantly when cold, think about worrying.
ALLSTOCK
DMV
oh i didnt know it expands when hot.
Just checked when cool and the levels are good.
Saved a turkey baster.
Thanks!
