In Track Mode zero throttle till 100%
Spykexx
Quad Cities, IA
2021 Mach 1 VMP Odin, 2025 Mach-E
Morning all,
Recently picked up a Mach 1, that has a VMP Odin kit on it. But I figured I would toss this in the general thread as I don't THINK it's FI related (outside of the tune more than likely).
All my modes seem to work as intended, just fine, except for track mode. Normal, Sport, and Drag work entirely as expected.
Track mode, I have to push the throttle to 100% before it even registers the throttle is pressed. It doesn't run rough or anything else, it just acts as if you aren't touching the pedal until it's to the floor. Anyone else had this before? Out of the 5 or so other tuned S550's I've owned none of them had any effect on how the modes worked.
Whitedevil95
Temecula, CA
J.P.
2022 Mach 1 HP
Who is the tuner?
Spykexx
Spykexx
Quad Cities, IA
Who is the tuner?
About 99% sure it's VMP base tune based on the info I was given.
Partially why I'm curious if it could be tune based, as I was going to change over to Wengerd just to know exactly what's on it.
robvas
MI
2011 GT
Can you log your throttle/pedal actual vs requested? See if it moves along with the pedal
JVO21303
Tucson, Az
Jose
2015 Mustang GT stage 2 stage 2 supercharger, FBO, E85
VMP is garbage. Let’s just start there. Go with wengerd
Whitedevil95
Temecula, CA
J.P.
2022 Mach 1 HP
If it works fine in all other modes but then changes only in one particular mode, I would say 99% its a tune issue.
