How to prevent nose dive on hard acceleration
302@12psi
MD
2019 Kona PP2 Recaros
Haven't been able to take the care out for a few weeks due to the weather. Today while out and about I noticed on hard acceleration the nose dips down on hard acceleration in between shifts. It has happened before but don't think the car does it every time.
Whats the best way to prevent this? Slower release of the clutch? Slower to get back on the gas? Faster shifting between gears? Or is it just what it is?
S7N
757
Earth
2022 KIA STINGER GT1 AWD
It is what it is outside of lowering the car with springs and upgrading to stiffer struts and shocks.
frank s
san diego CA
www.fsheff.com
frank
Stang '19 Magnetic, EcoBoost™, Vert, MagneRide® PP
The natural effect of removing power to the rear wheels would be a drop in the front of the car. It would be more dramatic if the foot came off the gas before the clutch disconnected the engine from the differential.
Adjustable shocks and struts can mitigate the first effect to some degree; better gas/clutch coordination should eliminate the second.
Chris Barnes
Arizona
2021 GT500
More rear brake helped my car. I upgraded the brakes including the rears and it had a profound affect.
Shifting_Gears
South Florida
Shifting faster will reduce it as there will be less time that there’s a dip in power to the wheels.
Different suspension tuning can reduce this as well, but primarily by reducing the rear end squatting in the first place, keeping the nose more level.
fiveoboy01
Madison, WI
2017 LB GT 400A
Re
Rear brake? On hard acceleration? WTF?
Yeah, I think he's getting confused with nose dive under braking.
OP - just install an automatic trans. :p
Hack
Minneapolis
Mustang, Challenger
Magneride, PP2, stiffer springs and shocks all help improve body control. Or if you buy a car that's lighter and lower to ground like a Corvette. I really liked my GT350 for great control of body motion. The nose still comes up under acceleration though. I've noticed that the nose on my C5 barely lifts at all. But there are other things I don't like as much about it.
NoVaGT
Northern Virginia
2019 PP1 GT Kona
OP has PP2.
OP, is your car boosted?
Stephen@lethal
2020 Mustang Gt500
Best way to fix this issue is power shifting into gear to carry momentum onward instead of letting gravity work against you.
Jimmy Dean
Gonzales / Pierre Part
Al
stiffer rear springs, or get the front shocks tuned for a longer dwell time. Since you have magnaride it may not be too hard. or could be very hard.
what suspension setting were you in at the time? I am pretty sure the road setting is pretty soft, the track setting should not have much issue with nose rise and dive.
302@12psi
MD
I was in Normal at the time. Perhaps that might be my perception issues as I don't recall the car being so dramatic previously. I'll have to explore the other settings and take note.
