arellanosbb
I have a 2017 mustang gt everything is stock but I want to know if I need to do anything to the engine before running nitrous?
That's what nitrous controllers are for. I wouldn't worry about a 100 wet shot & no tune. 200+wet shot w/ tune I'd better hope all the stars are lining up & the octane Gods are smiling upon me.The problem with a wet shot is that neither the nitrous system nor the pcm have complete control over fueling. There are at least 20 different reasons the pcm could decide to cut fuel. This is safe because no fuel means no problem. But if the wet shot continues supplying fuel then you wind up with an extreme lean condition.
Traction control, over-rev, speed limiter, shift torque reduction, etc are just a few examples of reasons it might cut fuel.
Maybe I’m not following but let’s say you’re at 5000 rpm and everything is fat and happy. Then the pcm decides to cut off fuel to 3 cylinders for any of 20 possible reasons to do so. Now you’re still getting fuel from the wet shot into those 3 cylinders but about 1/5 of the fuel you need. How does a nitrous controller help you in that situation?That's what nitrous controllers are for.
That’s the thing about the torque reduction strategy…if it can’t get the desired torque reduction with timing retard, it will start cutting fuel to cylinders. There’s no practical option to turn off fuel cut and as long as it’s a possibility then bad things can happen.Edit - with proper tuning.
When the throttle is cut, it'll turn off. Low fuel pressure same deal. You are talking stock tune.. so unless your racinging on the street with radial TA's and all the nannies on.. You shouldn't have a problem. Also how will it cut fuel to just 3 cylinders on a coyote ? AFAIK they're either all on, or all off.Maybe I’m not following but let’s say you’re at 5000 rpm and everything is fat and happy. Then the pcm decides to cut off fuel to 3 cylinders for any of 20 possible reasons to do so. Now you’re still getting fuel from the wet shot into those 3 cylinders but about 1/5 of the fuel you need. How does a nitrous controller help you in that situation?
