Hood vents
Pilgrim/uk
Clowne
Brad
GT Yellow
Does anyone have the dimensions for the holes need to be cut to fit the vents got mine a before car arrived still not fitted yet i think its about time they went on lol just need the measurements lol
Rapid Red
Woodstock GA
Greg
Think if you told folks who the vent is made by... might get the answer you're looking for.
Some require no holes drilled... Roush one does..
Pilgrim/uk
Pilgrim/uk
Clowne
Brad
GT Yellow
Stock US ones lol pre facelift
Rapid Red
Woodstock GA
Greg
Now that will be a challenge, it might be posable , let me check on something.
Rapid Red
Woodstock GA
Greg
Looked at the Roush install instruction, sometimes they offer templets . No go, best suggestion I can make.
First does the vent have studs or threads.
To find the spacing of the hole or studs You want to measure from the OUTSIDE of one, and over to the INSIDE of the other
Say the distance is 4". Center punch plastic, want a material that will hold it shape.
Drill the 2 holes, then check by pushing the vent studs thru or screwing it to the vent.
V________________V
O_________________O
Outside..................... Inside. that distance is the center between the 2
As to the hole for the vent hot air exit, the underside of the vent should have that. You are going to need a templet that represent the hood, not the whole hood, just the mounting area. to mock that heat extraction hole.
The next challenge will be the spacing, will need to pull the padding down to check the underside of hood, locate stiffing braces, want to avoid cutting those.
Going to take some work, be prepared
Charlie Brown
Leamington Spa, UK
17MY Mustang GT Auto Race Red Custom Pack
Mike at Modurstang has done loads of these - including mine - he does a great job and uses a bracket as well as adhesive
Alfa Male
Worcestershire Sauce Country
Alfa Giulia
just about to type the same thing. Particularly about the need for a securing bracket to stop them flying off at high speed which others have suffered from when retrofitted.
Pilgrim/uk
Pilgrim/uk
Clowne
Brad
GT Yellow
Lol I know he does them its just that he is about 400 mile round trip from chesterfield area
Pilgrim/uk
Pilgrim/uk
Clowne
Brad
GT Yellow
Yep that why I'm asking if anyone has the measurements for the position of them on the hood/bonnet i have searched the net but cant find a diagram of the position
Rapid Red
Woodstock GA
Greg
Man I totally miss the question you had asked. You could actually get pretty darn close
Take a picture of the front half of hood on a car with vents. Make sure you have the hood side body gaps.
Measure the same body line on your car, then the picture. Devide the picture measurement into your hood measurement. That will give you a scale. * #
From the picture make measurements. Multiply those by the number from the division found above * #
Might be too much math, it is not really. But chances of finding someone that will let you drag a tape measure. Across the hood of their Mustang will be much harder. LOL
Or grab your wallet, that you're most likely going to do anyway. Go to a body man or FORD give the task to them.
FYI all hood vents use 3M double sided tape. Zero chance a vent will blow off.
Guy with the over night bonding hype is hozing you, probably owns LOL The hotel next to his shop for overnight guest,
Cheers,
Charlie Brown
Leamington Spa, UK
Cheers,
Sorry pal but you’re wrong our hoods/bonnets in the UK do not have the recess for the USA hood vents and those that have been fitted over here without the bracket have indeed “flew off” and our mustang specialist over here (Modurstang) that fits them with brackets is a highly reputable and skilled technician who definitely does not (how do you put it hoze) his customers and does not own any hotel nearby
spogshd
manchester uk
2016 convertible
V8_MOTOR
Nottingham, UK
MY17 S550 Mustang GT (EURO)
if you take the sound prrof material off, you will see where the US ones go one. then its just a case of lining things up. any decent bodyshop will be able to do it
alternatively, buy a cervinis hood. They fit perfect. Ask me how i know :D
Rapid Red
Woodstock GA
Greg
Driving to fast LMAO ....it's good to be in the USA
Cheers,
