honeybadger
Just don't care
More progress tonight. I finally got a method down for removing seam sealer, sound deadener, and other treatments. I've discovered that the right tools and method is critical. Previously I had tried a heat gun and paint scraper - that worked okay on the sound deadener "mats" that aren't super well attached. However, with the "wipe-on" deadener, it was fairly ineffective. I also tried dry ice and alcohol in a previous run at this in 2020 and found it to be "okay" with this deadener material.
Okay - let's get on with it. First, here are the tools I used. IMHO, a respirator rated for mold is critical to combat the fumes from burning the sound deadener/seam sealer. And the full face shield is highly suggested if you're using an angle grinder or wire wheel. Not pictured is the fire extinguisher. Reminder that you should always have a fire extinguisher in your shop - especially if you're working with flames/welding, etc.
First, heat the seam sealer with the torch
I only get it to start turning brown - basically enough to soften it. This section only took about 10 seconds.
Get your wood chisel and start whittling it up. IME, if it's hard, you either need more heat or you're getting snagged on one of the layers of metal.
Should look something like this when done
Okay - moving over to the driver side wheel well, you'll see that the same method exposes a gap. There's a decent amount of material still in there, so I started with the wire wheel on the drill pushed into the gap to clear it out.
Looks like this after.
This is easily removed with the pick
Now just run over all the seams with the wire wheel on the drill to clean up the remaining sealer left behind.
Full "rear seat" area done tonight. I used the same method on the sound deadener that was on the wheel well that you can see below. I'll share some additional details on that and when I used the wire wheel/angle grinder tomorrow when I shift to the trunk and firewall.
