help with wheels
MAGS1
Somewhere in Middle America
2022 Mustang GT
Ahh ok 20 / 10 all round then I guess that would be 275/35 all round. It currently has 19 / 9.5 255/40, 19 /10.5 275 /40, on 25mm spacers. I guess the new setup for square would be 20 / 10 275 /35 all round and drop the spacers
For 20x10, go with 285/35. That’s what I run
neucleator
neucleator
Devon
Ford Mustang GT V8
I might go with bronze like I have on the rangey I think goes quite well with the blue
GTP
Deutsche Pony
Indy
www.BambergAudio.com
Philip
I think ive found them gonna go with set of 20 of these with 4s all round me thinks as they are gloss black inside then machine diamond cut with smoked gloss finish on the outside so you can still see the style
(Sigh) Wheel shopping ...
Please take your time, even though it is exhausting. You get one good shot at this and you don't want any buyer's remorse.
First, be very sure you want 20" over 19". Compare prices on wheels and tires. Even availability. Many of us (me included) think the 20's have that Hot Wheels look.
Next, if you start to research and learn all about wheel fitment, you can always use this calculator to model sizes. Note that you want the overall tire diameter to be around 700mm.
Finally, color is also an important one-shot choice. I agree about black wheels. They just don't "pop" as much as you think. I used to own the pictured wheel, Enkei TY-5, for about $300 each. They had mirror cut faces and a tinted clear topcoat. They looked just black most of the time. Only in the sunlight at the perfect angle could you see the mirror faces.
NHMach1
Nate
2020 Mustang GT
I would also check out the Vendors on here that know the correct offsets, sizes and recommended tire sizes to match. Project6GR website is a really good tool
MAGS1
2022 Mustang GT
OP, here’s my 20x10 with 285/35 all the way around. Stock, non-magneride suspension
MAGS1
2022 Mustang GT
20’s will be heavier than 19’s. 20’s fill the wheel gap a little better. All depends on what you’re looking for.
0wen
Cambridge, UK
Owen
2021 Mach 1, MX-5 30th Anniversary
Just my opinion but you could lean further into the GT350 look you've got going on and get some Project 6GR 7s in a squared 19" / 30 offset fitment, and run 285/35 PS4S or Conti SC7s.
I'd avoid 20" for a couple of reasons but that's just me.
Also agree with @MidwayJ that black wheels would look better with Grabber Blue, like on @MAGS1 car but Anthracite could be an option.
-0wen.
As an example (photo credit Mustang Week on facebook)
Yes those might but the OE carbon wheels but they'll look almost identical! :)
23GreenGremlin
Mechanicsburg, PA
2023 Mustang Mach 1, P0389, Eruption Green, "Gremlin"
Mine is not the same color as yours but I do think bronze wheels look good on mustangs. Then again I may be a bit biased.
Wheels are 20x10 and 20x11s.
Robbo70
Melbourne Aust
2017 Mustang GT
Be aware most 20” will be heavier and also compromise ride unless you go fully forged.
23GreenGremlin
Mechanicsburg, PA
Not necessarily. My Halibrands (not forged) with tires in a larger overall size than the stock Ford wheels still came in about 5 lbs lighter. I'm also perfectly happy with the ride quality. I suspect the MagneRide shocks help a bit. The thing that helped me decide to go to 20" wheels is that there are a lot more tire choices in that size. Not easy to find a 19" all season performance tire over P275.
MAGS1
2022 Mustang GT
Same here, my 20’s are lighter than OEM 18’s but only by a few pounds. They’re heavier than other flow formed 19” wheels though. The cast OEM wheels are heavy
neucleator
neucleator
Devon
Ford Mustang GT V8
Yea sod it black does sort of seem to look like its meant to be, ive got a lot of ai testing to do
blankman
CNY
2023 GT
Gotta say I love the look of gloss black wheels on certain cars. My car is a darker blue but I absolutely love them, and I get a lot of compliments during the daytime when you can see them.
5.0_Lojos
Miami FL
Carlos
2016 Mustang GT Premium
I cannot decide what to replace the stock 19s with. im definitely going to go 20" either gloss black like they are or maybe a carbon colour, what do you think, love to see what others have opted for?
Black is hard to beat. Gives it a nice clean look, fills in the wheel well (illusion wise) and God forbid any curb rash happens all you need is some black touch up paint 👍💯
neucleator
neucleator
Devon
Ford Mustang GT V8
Yea im going for black im going to send off the calipers to be power coated then re do thr brembo logos on the front so ill get some fairly open black ones with a fresh set of discs and freshly coated calipers which will help make that area pop
