Help, Shop header install fail
DeepakGTCS
Vancouver
21 GT PP1
Got my headers installed from a shop, was happy until I noticed an exhaust leak somewhere 3 days later, went back and left the car with them for the day. 1 day goes by I get a call and they say everything is good bolts have been tightened down. Seems good, hop in the car and drive home so far so good, car was at temperature. Shop worker said that I may need new clamps for my x pipe, okay no problem. Go home and order some off summit racing. Park the car for 3 hours get back in and start the car and theres a leak I heard previously. Hop out and reach down the passenger side of the engine bay and feel large plumes of air shooting out. I found the suspected leak. Seems like the shop may have not done the work properly as they stated and lied. I am disappointed and it looks as if one of my bolts for the header is bent. Contacted the shop owner and he promised me they checked every bolt, sent him the picture and his story changed, saying he would fix it 100% after I told him I'd go to another shop and have them look at it. What would you do? Would you try and fix it yourself?
coyote-ugly
winter haven Florida
Dustin
2015 gt premium
Fool me once shame on you, fool me twice..... I think I would find another shop. You're going to see that they probably buggered up the threads on the head.
DeepakGTCS
DeepakGTCS
Vancouver
21 GT PP1
I know, I'm so mad. I don't know what to do since I paid these guys a good chunk of change to install them.
GT 550
Australia
Black GT MT S550
If I'm not mistaken it also looks like the bolt closest to the camera isn't doing anything, threads are still visible between the head of the bolt and the header flange?
DeepakGTCS
DeepakGTCS
Vancouver
21 GT PP1
It's in there just needs to be tightened down, If I have time tonight ill back the bent one out and tighten the one thats loose.
GT 550
Australia
Black GT MT S550
Might be worth checking bolt length first, could be they used a bolt that was too long and when they couldn't turn it any more because it's bottomed out in the hole they assumed it was tight on the flange. If so, any further force could strip the thread.
DeepakGTCS
DeepakGTCS
Vancouver
21 GT PP1
They are all the same length bolts from the pypes kit
scrubber3
Hopper, is that you?
Sandhills NC
2017 GTPP Shadow Black. 2001 Jeep XJ 4x4
I wouldn't touch it. Let them look at it again. Have the shop owner do it himself. Whatever tech did that may have stripped some threads in the head. If that's the case, it's going to need more than new bolts. If you haven't touched it, they cannot put any blame on you.
IvanCRF
El Paso, Texas
5.On'ry
After seeing the pictures, for your safety, double check the engine mounts and the other fasteners.
TGGT
SoCal
2018 mustang gt
The one bolt definitely looks cross threaded. That’s all bad if it is
TGGT
SoCal
2018 mustang gt
Op where are you located?
1TUFF_S550
Richmond Ca
JESSE
2017 Mustang GT PP. 2001 Mustang GT Cam’d & Vortech’d
Sucks big time!! Hope the shop straightens everything out for you man.
Stroked89coupe
Centerville, GA
Parker
S550
I would expect at a minimum of an explanation on how they were going to correct the issue with the cross threaded bolt to ensure they were going to do it the right way. That would be my main concern. I mean honestly, depending on a few things like how far the bolt was cross threaded into the head, they may just be able to re-tap it with the same thread pitch and type and be ok. Just really depends.
Strokerswild
Shallow and Pedantic
Southern MN
Things With Wheels
Yikes. I would be livid....
That top bolt in the pic is almost definitely cross threaded. I'd wager that hole is beyond tapping and might require a Helicoil. As to why the lower one isn't seated against the flange is a mystery since it appears to be going in straight. Unless any misalignment of the flange caused by the "top" bolt being botched made the "lower" one bind before it seated. Not good....
