Help removing valve cover , doing the opg
v8ter
Typing...
EL PASO , TX
MUSTANG GT 2015 50TH
Can somone help me on how to get to the rear bolts on the valve covers? I cant get to them to remove them
v8ter
v8ter
Typing...
EL PASO , TX
I didnt remove the battery tray,gona do that and looks like its gona get me the access I need
z06psi
Evans, GA.
Andrew
The pot stirrer
1/4" ratchet is your friend in this case. I also used the "pass through" sockets and ratchet you can get from Lowes.
RockStang
AA county MD
Joe
2016 GT Whippled
17GT
2017 Mustnag GT
I just used a 1/4" ratchet with extension but I did remove battery and tray. Only took a few minutes and made things much easier. You think that bolt is tough wait until you get to the pick up tube bolt. Total nightmare.
Bartly
Out West
2016 Mustang GT
... You think that bolt is tough wait until you get to the pick up tube bolt. Total nightmare.
Have any suggestions if you were to do it again.
z06psi
Evans, GA.
Andrew
The pot stirrer
Yep. Dropping the oil pan might have been easier. That one bolt took 4 hours.:frusty:
17GT
2017 Mustnag GT
Hmmm my post disappeared. Anyway, you absolutely need a ratcheting box wrench. Place a towel in the pan below the bolt and just take it slow. Took me 20 minutes to remove. Now the fun part. I used a small wire wrapped around the bolt to hold it in place while I was able to slowly get the bolt started with the pad of my finger tips. Very frustrating endeavor. Took over 30 minutes to get it back in.
v8ter
v8ter
Typing...
EL PASO , TX
v8ter
v8ter
Typing...
EL PASO , TX
After removing battery tray, was easy to remove,the pick up tube bolt was pretty straight forward, I have small fingers so I could place one finger from the back and one from the front and rotate it slowly and was back on in 10min
v8ter
v8ter
Typing...
EL PASO , TX
z06psi
Evans, GA.
Andrew
The pot stirrer
Down side of having Gorilla hands like mine. However there are other benefits. :D
esacteksab
CO & KS
2015 Mustang GT
I went and got a adapter so I can use any socket on it like that,worked great!!
While the swivels are nice, they add extra length. These don't so in those situations where you don't have the room for that extra joint, these are nicer.
Slamdcoop0428
SW Florida
2016 Mustang GT Premium auto
My tool for the bastard oil pump pick up tube bolt. Made life so easy. As i can fit it under the crankshaft snout and get a really good turn on it.
