HKusp
- Jul 22, 2021
- Hampton, Md.
- Jason
- 2018 Mustang GT
Those are some wide-ass feet!! Lol.HB makes an excellent point about cars being deliberately setup for engine braking. Although the braking force it provides is small compared to the actual brakes, there's margin left in the rear axle in order to make sure the car is balanced front to rear while braking hard in gear with the engine high in the rev range as it should be on a track. And again it's not a lot of margin, if you try to add 3000RPM to the engine with that margin instead of doing a throttle blip, you will cause the rear axle to briefly lock up if you're braking as hard as you should be before corner entry.
That's another reason why I'm so bothered by the Steeda video, the guy is holding the clutch pedal completely to the floor for like half a second every time he downshifts. So he's just braking and coasting that whole time.
Just as a sanity check, I went out on my lunch break and heel-toed the truck to see how hard it is.
Yup, still works.
"If you can dodge a wrench, you can dodge a ball!"
