Got side swiped. Should I polish or repaint?
Lunixor
Vancouver, BC
Giovanni
2022 Mustang GT
Today while my car was parked at work, someone side swiped the driver side of my front fender and bumper while pulling out of their spot.
I’m pretty upset because this car is only a year old and I’ve kept it in meticulous condition, with constant detailing. I barely even drive it.
Now as a result of the side swipe my car has some scuffs and scrapes along the side, and a small dent. Looks like a little bit got chipped off as well.
It seems like I have two options:
  • Take the car to a body shop where they will likely do a repaint of the fender and bumper
  • Take the car to a detail shop so they can attempt to buff out/polish the paint, touch up the chip, and pull out the dent
What would you guys do in this situation?
I’m worried that the detail shop won’t be able to get it back to looking 100%, but at the same time, I’m afraid the body shop will not be able to match the colour properly (rapid red) and I’ll end up with mismatched panels.
Brisvegas
Brisbane
Pete
Dark Matter Grey '23 GT Mustang , 1976 SS Torana
I'd replace and respray the fender , but certainly worth trying to find an undamaged rapid red fender first for the easiset fix of all .
Lunixor
Lunixor
Vancouver, BC
Giovanni
2022 Mustang GT
I hate thieves. Any cameras catch the culprit?
They left a note actually and were quite apologetic. They also offered to pay for the repair. I’m just concerned with how I can get the repair done in a way where I’m not gonna notice the defects later.
Jackismydog
L'Islet,Qc Canada
Francois
Mustang GT 2016 Convertible
I would start with polishing. If you are not comfortable to do it yourself, take a chance with a detailing company in your sector
Tucker80
Aaron
2022 Mustang CS, 2024 Civic Type R, SV650
I wouldn't even consider any option other than a good body shop. Matching paint for a good tech isn't that hard. You just need to make sure to do your research and find the best in your area.
Crew4991
Phoenix Arizona / Denver Colorado
Crew
Ford Mustang GT/CS, Dodge Viper SRT10
Sad to hear about this incident. The scratches are noticeable but are in a smaller area based on the phots, I bet a good polish would do the trick.
When it comes to situations like this, start easy with a polish and see if that works, then go more difficult with a repaint if you are not satisfied. Best of luck with the repair!
fast306stang
GA
'22 M1HP6MT
+1.
Try the easy/cheap way first--polish. If you don't like the results, then get it painted. Looks like most of that will come out. But if you paint first, you'll never know.
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
That should buff out. I'd still want it fixed or replaced due to the dent.
WD Pro
United Kingdom
Lime GT
I think you will get everything out other than this in the bottom left where its gone down to plastic :
And maybe the single deep scratch in the top right (which could be reduced / made to look better).
Use PDR for any panel distortion.
At that point you will have a decision to make i.e. live with it looking much better than it does now, or go down the bodyshop / paint route.
Nothing to lose by trying the polish and PDR route first :like:
WD :like:
Mojo9691
MI, USA
Todd
2022 Mustang GT/CS - Mischievous Purple
Take it to a competent bodyshop and it should be an easy fix.
Tucker80
Aaron
You guys are way too nice! The OP's car was damaged and the other party has acknowledged financial responsibility. Not a chance I would be trying to do anything other than get it repaired back to factory original condition.
Egparson202
2019 Shelby GT350, 2018 Audi TTRS
You’re not wrong. I’d at least start with a search for the right body shop for a consult. Ask a Pro. decide for yourself.
Decible
Georgia
Sam
2023 Mach 1 HP
Start with a polish to see if it will clean up. If not check thepartsfarm and see if the have an undamaged fender in your color and replace. 2 cheapest options and keeps the carfax clean.
Lunixor
Lunixor
Vancouver, BC
Giovanni
2022 Mustang GT
I washed the area and applied some polishing compound. Got it looking better but there’s still a dent and some scrapes.
I took it to a body shop for an estimate and they would need to sand and repaint both the bumper and fender to get it looking new again. $2400 cost.
I’m going to get it checked out by a detail shop though to see if they think they can polish out the remaining scratches, but I think they’re deep in the paint so probably not doable.
