Gen 3 Coyote measurements
pro 5.0
Canada
2019 Mustang GT
Car is a 2019 PP 1 A10 build date was Nov 2018, the tick and 2K rattle both started around 200 miles on the factory oil, current mileage is 870 miles although this is low it shows that there is no damage in the short block even with the noises present. I measured each set of rods as a pair and on all 4 crank pins along with the crankshaft end play, the cylinder walls are mint and do not have any scratches or scoring. I have also cut open the oil filter once at 400 miles and the second at 800 miles, both times there was no metal present just a couple strings of black silicone. Factory spec for the connecting rod side clearance is .0128 - .0197 and max crank end play is .011, you can also see that the connecting rod in no way contacts the piston in the wrist pin area. I guess the mystery continues as to what is actually causing these noises as I found nothing wrong in this engine.
Dusten
Conway, Wa
Dusten
2018 Ford Mustang, 2001 Ford Lightning, 1968 Ford Mustang
Good info.
NastyPumpkin
Michigan
2018 Boosted Mustang GT
Excellent post! This new Coyote engine is a power Beast.
VinnyVicci
Michigan
Vince
2019 Mustang GT
So what do you think is causing the tick or rattle if the engine is healthy and on spec?
NastyPumpkin
Michigan
I was told "cavitation" by the Ford Mustang Powertrain Engineers.
Condor1970
Port Orchard WA
The Typewriter tick is oil cavitation. I'm pretty certain of that now.
The 2k Rattle sounds an awful lot like the mechanically driven High Pressure Direct Injection Fuel Pump on top of the engine. it is a plunger type pump that is lobe driven off the camshaft. At certain RPM and fuel pressure depending on throttle position, it will make a harmonic noise that is quite audible, and sounds like a rattle. The same noise can be heard in the Ecoboost engines as well, especially since the pump is almost identical in design. In fact, it may even be the same pump with a different plunger size adjusted for flow rate of needed fuel supply.
pro 5.0
Canada
2019 Mustang GT
There are a couple of things to note, the valley in the Gen 3 has 2 big foam type inserts in the front and back of the block. These do not exist in the Gen 2 so the direct injection must be responsible for some noise as the inserts are there for a reason. There is actually a roller lifter between the pump plunger and the cam lobe which drives the pump, the plunger in the direct injection pump is very stiff as it takes a lot of pressure to compress it. If someone was willing to try it you could remove the lifter and the direct injection pump would not operate and if the noise went away there is your answer, however I'm not sure how much of the fueling goes through the direct injection side the car may or may not run well enough to test the theory.
GT Pony
Pacific NW
Good info on the lower end measurements. Did you also verify the rod side clearances with the feeler gauge method? Do you also have a video of this engine idling with the typewriter tick happening?
There were some typewriter ticking Gen2 Coyotes reported that had excessive rod side clearances - one was twice the maximum spec. The Gen3 Coyote has it's own unique set of noises, and yes the typewriter tick is still one of them.
What would make one engine tick from "oil cavitation" vs another identical engine running the same exact motor oil? Still too many unsolved mysteries.
pro 5.0
Canada
2019 Mustang GT
Dial indicator is the preferred method as a feeler gauge can very a few thousands depending on feel / drag. I'd have to look and see if I have any video footage I'm not sure that I do, however I can tell you it doesn't start to tick until about 4 mins after a cold start. I tried Ceratec and it seemed to make the tick go away temporarily but it soon returned, this leads me to believe it's related to the oiling system. This engine has so many aspects to it that I believe OLD SCHOOL thinking regarding noises such as piston slap being the 2K rattle are out the door. The cam phasers are not concentric and when you turn the motor with the spark plugs out so it's easier to turn the chains and tensioners make noises as well. I think all Gen 3 engines make the tick and 2K rattle but some just don't hear it and swear theirs doesn't do it.
boB
boB
2019 GT PP1
There you go, ruining everyone's fun with facts and data. ;) Thanks for taking the measurements! I was considering it if it wasn't so involved (1+ day of wrenching).
GT Pony
Pacific NW
Would have like to hear a recording of the engine noises to see what it sounded like. Lots of noises are misdiagnosed, and that's not meant to be anything against your knowledge and efforts pro 5.0 which is appreciated for sure ... just part of any kind of investigation when collecting facts.
pro 5.0
Canada
2019 Mustang GT
I found a video on my phone it's 30 seconds long and too big of a file, I'm trying to trim it down stand by.
