Gear ratio issue
GreenS550
Houghton, MI 49931 Oakland, MI 48363
Bob
2019 Mustang GT Premium 2020 Explorer Limited
I have been thinking of how to get more grunt off the line in my Bullitt. These gears coupled with the higher RPM of peak HP has me looking at options. Yes, I could put a 2017 MT82 in my Bullitt. Too expensive and other issues. May as well put a blower in for a few bucks more.
So, I compared gear ratios of our Bullitts with pre-2018 Mustang GTs. Here are links to the two specs:
https://media.ford.com/content/dam/fordmedia/North America/US/2015_Specs/2015_Mustang_Specs.pdf
https://media.ford.com/content/dam/...ses/Mustang/2018Ford_Mustang_Tech_Spec_EU.pdf
Ford does state the ratios are to meet mileage standards. Apparently just a bit of shifting with our more powerful cars could drop MPG 1 and make our Mustangs "gas guzzlers".
So, doing a bit of math, for 1st to be the same final drive ratio as a 2017 GT with 3.73s our Bullitts would need a 4.21:1 axle ratio. That ratio, if it were available would still leave 2nd a bit longer than the 2017 transmission. These are really long gears.
Now that said I'm thinking 4.11:1 albeit a bit longer than the 2017s might be just perfect. With our ridiculous 6th gear, highway cruising would still give decent 22-23 MPG.
Any thoughts?
Bullitt0819
Modesto, CA
Bob
2019 Bullitt Mustang
Sounds appealing; I rarely hit 6th at it is. Is the new IRS as easy to swap as the old 9 inch? Would you have to buy a 'tune' in order to change the speedo readout?
GreenS550
GreenS550
Bob
You would need a tuner or some device. Since I have the Steeda tune and an SCT 4 tuner oh, it would be simple. The nine inch differentials of long ago or a pig style or third member. Our IRS differentials will just require having the gears replaced and set with proper backlash and thrust washers. I'm thinking probably $300 in labor and $300 for the gears. Something like that. I'm wondering if done at a Ford dealer if it would still be warranted. I don't know the answer to that.
Bullitt0819
Modesto, CA
Bob
... Our IRS differentials will just require having the gears replaced and set with proper backlash and thrust washers. I'm thinking probably $300 in labor and $300 for the gears. Something like that. I'm wondering if done at a Ford dealer if it would still be warranted. I don't know the answer to that.
Can the swap be done in situ, or do you have to pull the diff?
Schwerin
Home
2019 Mustang
I find it funny how many complain about the long gearing but most the gears are +0.10 more than the 3650 in the 01-04 3650 tranny and that made a lot less TQ.
Just do like we did 15yrs ago. Put in a 4.09 or a 4.30, 4.56 if you drag, and call it a day.
aileron
Montana
Dick
'19 Bullitt K1191, '20 BMW X3 M40i, '17 BMW 440xi, '14 Ram truck...and 19 old Triumph motorcycles
Just do like we did 15 50 yrs ago. Put in a 4.09 or a 4.30, 4.56 if you drag, and call it a day.
Fixed it for you :)
Racerx009
North Carolina
Anthony
2017 Ford mustang gt non pp
Any thoughts?
I installed 4.09 gears in my 2019 Bullitt pulls hard and no highway issues. I think 4.11 would be even better
OvalBlue26
Arizona
Kenny
2019 GT Bullitt
Racerx009, Did you have any issues with throwing codes or speedometer calibration after the 4.09 R&P install? I ordered the 4.09 and am trying to anticipate any issues. Thanks.
Schwerin
Home
2019 Mustang
Everything I've seen says that manual cars don't need to be calibrated, only Auto's
OvalBlue26
Arizona
Kenny
2019 GT Bullitt
I reached out to Ford Performance and got this reply:
Yes, you will have to find a calibration to adjust for the 4.09 gear. If not you will have issues.
Ford Performance does not have one for the Bullit.
Matt Korczyk
Ford Performance Parts Vehicle Coordinator
Ford Performance Parts Tech LIne
(800) 367-3788
ice445
Salt Lake City, UT
2020 Mustang GT 6MT
2019 and newer will need tuning for any ratio over 3.77. This is because of the auto rev match mostly because the computer doesn't have tables for anything over that 3.77 mark.
