Gauges
gone_n_60
Indianapolis
Whit
2020 Mustang GT PP Convertible
My layman understanding is that the engine temp is the critical operating parameter, which, in normal cars you can only observe indirectly, through the coolant water temp (or the engine oil temp). So even if the other indirect systems fails, you still get the info about the engine temp, right before it explodes :wink:.
Thinking this is the indicator that if goes too high puts you in limp mode?
tom_sprecher
Living Race Car Free
Marietta, GA
2016 GT Premium PP 6MT Race Red
Cylinder head temp and oil pressure. I wish the vacuum gauge was oil temp instead.
GTP
Deutsche Pony
Indy
www.BambergAudio.com
Philip
joepro
Torrance Ca
22 Mach 1
Diff Temp, Head/Coolant temp/oil pressure in the Cluster. I have considered swapping to the GT350 Oil temp gauge, but I'm still not convinced it will be accurate based on how the gauges work(calculated from other data inputs from my understanding). If someone were to somehow verify it does work properly(I haven't researched it in quite some time so there could be new info) I would probably swap it in a heartbeat, the VAC gauge is utterly useless, and annoying. Might just swap it because of that...
VladDracule
New Mexico
2014 Mustang GT/CS
Please stop calling you car SKYE, its getting awkwardly uncomfortable, LOL.
PS/Just messing with ya. But...
NGL a buddy from work said I have to name my car, and i though you know Skye is actually a pretty good name for a grabber blue mustang, so i thought about stealing it but i was still unsure if their name is actually skye or if they just made their forum name skye, so ill add to the confusion and start referring to my car as skye from now on
JetGray_Mach1
Southern California
Martin
2022 Mach 1 (HP)
stev3french
2021 Mach 1 Twister Orange w/HP
I replaced my vac/oil pressure gauge with the GT350 one that shows oil preesure/oil temp. It is totally plug and play and looks stock obviously. The car should've come with this gauge pack imo.
Firsttexan
2011 GT500 '19 GT PP1 '13 GT500, 98 GT, 92 LX 5.0
Head temp, Air intake temp, Trans temp I flip between gauge and digital readout depending on mood or need for accuracy.
SemperFi
Jacksonville Florida
2021 Mach 1 m0303
I got me one of them tree air fresheners on account I have ventilated seats and when I fart, I end up punishing myself. It's not really a gauge or nothing, but it is an important aftermarket add on.
GTP
Deutsche Pony
Indy
Philip
I read on 6g that a real sensor is in the cylinder head but water and oil temps are back calculated from it. Ie no actual sensors for those.
Happy to be corrected.
Bulldog9
Northern Virginia
2020 Bullitt, 2017 Tundra TRDPRO, 1976 Porsche 912, 1989 Porsche 944S2
Speaking of gauges, I just got a set of GT350 Oil Pressure and Temperature gauges for my Mach1 HP! Now I just need the car.
Hey, why is your girlfriend in your avatar? ;-)
Cobrajet70
clermont
Jamie
21 Mach 1 Hp
Axle, CHT, Trans
GT 350 Gauge is there so I don't have to run CHT.
It's called the ICM (INFORMATION CENTER MODULE) it reads off High speed can straight from the PCM, only PIDs for it are Turbo press ( for pressure and vacuum) EOT and oil press. As far as the Wiring Diagrams go CHT is really the only real temp sensor but other are there as fuel temp Air temps and so on.
Not including Axle and trans.
